According to the Porsche 911 Workshop Manual (under cam timing basic settings), you should set both cam punch marks facing up and cylinder 1 to TDC at Z1 on pulley. However, on my 1980 3.0L, only one of my cams has a punch mark. what do I do????
and no punch mark
Dan Criss ================== 1980 911sc wide body |
can you still see the "930" punched into that cam or is it too scratched up? the 930 needs to be facing upwards just like the punch mark
John A. 1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.) 05 Boxster S: For the Track. 06 Dodge Ram 2500 Power Wagon: Tow Vehicle |
Not sure if I cam still see the 930 mark. What about the cam lobes? Do they align somehow with the 930 and punch marks?
Cams
Just use the key way groove as the indication for the punch mark location
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
GOT TURBO..
Same lobbed on right cam..
As long as you can read it right side up your good.. There really is no exact posistion to install besides right side up.. I always install left cam first. Do intake rocker only on #1, set your cam timing, rotate 360 and double check then do #4 rocker intake only.. Limits your risk of bending something if it is new knowledge to you..
Super Moderator
As Mike said, the woodruff key position should be UP on both...
Thanks Guys,
I will set the "woodruff keys" up and set timing on cylinder #1 first then #4. Thanks again for your help.
Party Member
If you really want to sleep well, Dan, have a pro wrench check your timing. I did and slept great.
Seriously, I felt I had too much time and money invested to not insure this part of the assembly was correct.
Gary 71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure |
