-   -   MFI Throttle stops (http://forums.pelicanparts.com/911-engine-rebuilding-forum/368898-mfi-throttle-stops.html)
eapcpa 09-25-2007 09:32 AM
MFI Throttle stops
Help!! I sent some parts out to a local plating shop and they lost my throttle stops with the nuts. I think the size of the bolts are 5mm x.75 x18mm. Where can I get these or does someone have an old set of throttles that are no longer serviceable. They did send me two fender bolts for a Chevelle or something. Needless to say I am not happy about this situation.
304065 09-25-2007 11:43 AM
Here's a (fuzzy) picture of the head, it's a cheese-head screw with the tip filed down.
http://forums.pelicanparts.com/uploa...1145364365.jpg
McMaster has M5 x .8 x 20, are you sure that's not the thread pitch?
As an alternative you can call Matt Blast or one of the guys who rebuilds them.
HKZ Bob 09-25-2007 04:42 PM
Helllo John, where do you got the gauge from. Looking for this part since years. I only have pictures, like to rebuild them.
Can you help with some dimension details.
Bob
http://forums.pelicanparts.com/uploa...1190763576.jpg
http://forums.pelicanparts.com/uploa...1190763590.jpg
http://forums.pelicanparts.com/uploa...1190763619.jpg
Henry Schmidt 09-25-2007 06:04 PM
Originally Posted by eapcpa (Post 3497446)
Help!! I sent some parts out to a local plating shop and they lost my throttle stops with the nuts. I think the size of the bolts are 5mm x.75 x18mm. Where can I get these ...............................
All things MFI, where else ? SUPERTEC
http://forums.pelicanparts.com/uploa...1190768187.jpg
http://forums.pelicanparts.com/uploa...1190768280.jpg
http://forums.pelicanparts.com/uploa...1190768566.jpg
http://forums.pelicanparts.com/uploa...1190768631.jpg
Jeff Alton 09-25-2007 06:48 PM
I am pretty sure those are in vast supply here in metric land. If you still need them I will look tomorrow for you.
Cheers
eapcpa 09-26-2007 06:52 AM
Thanks for the response. John it is definitely not .8 pitch as those are very common. Henry I will e-mail you. Jeff Thanks for your offer, let me see if Henry can put his hands on some easily. I asked the plating shop if they sent mine to someone else and they said that was impossible. I responded with"you sent me two GM fender bolts that were somone elses!!" Long silence on the phone.:confused:
Henry Schmidt 09-26-2007 07:34 AM
Perhaps the largest selection of Porsche / Bosch MFI parts on the planet? Who knows.
The last law of business planning: Getting an ever growing percentage of an ever shrinking market is a blueprint for disaster.
http://forums.pelicanparts.com/uploa...1190816936.jpg
http://forums.pelicanparts.com/uploa...1190816966.jpg
http://forums.pelicanparts.com/uploa...1190816998.jpg
http://forums.pelicanparts.com/uploa...1190817032.jpg
http://forums.pelicanparts.com/uploa...1190817058.jpg
http://forums.pelicanparts.com/uploa...1190817087.jpg
http://forums.pelicanparts.com/uploa...1190817119.jpg
http://forums.pelicanparts.com/uploa...1190817246.jpg
http://forums.pelicanparts.com/uploa...1190817148.jpg
