-   -   3.0 with this manifold? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/369046-3-0-manifold.html)
FenderGuy 09-26-2007 07:42 AM
I bought this in hopes of putting EFI in my car....not sure it will work though..
It's a turbo manifold and was wondering if it can used as a EFI set up?
http://forums.pelicanparts.com/uploa...1190821316.jpg
http://forums.pelicanparts.com/uploa...1190821334.jpg
TimT 09-26-2007 09:04 AM
Yes it will work, but...
you'll need to get injector blocks and fuel rails for EFI injectors. Also that turbo manifold is pretty restrictive.
A much better choice would be a take off 3.2 manifold
FenderGuy 09-26-2007 09:10 AM
Tim
Thanks I forgot about the 3.2 manifold ...i should go that route
JohnJL 09-27-2007 03:08 AM
I use the 3.2 on my 3.0 EFI and it works well...watch out for the throttle linkage though. I had mine stick on WOT on the track today...
