-   -   Ring Position on a new 2.7 SET (http://forums.pelicanparts.com/911-engine-rebuilding-forum/369194-ring-position-new-2-7-set.html)
HKZ Bob 09-27-2007 04:50 AM
I just bought a brand new Mahle 2.7 piston set.
The pistons are already inserted in the liners.
Do I have to disassemble and check the ring position.
What is the OEM ring position for the three rings.
Regards Bob
cnavarro 09-27-2007 06:14 AM
I personally would, so as to clean them thoroughly and double check the gaps are correct. Ring positions should be 120 degrees off to minimize the chances of gaps lining up in and when there is ring rotation.
304065 09-27-2007 06:17 AM
I would definitely remove the pistons to clean the cylinders, who knows how much dust has accumulated inside. Wayne's book recommends putting the oil ring gap at the top of the cylinder to prevent oil leaking by, and the two compression rings at 90 degrees to the oil ring gap spaced 180 degrees apart.
V12man 09-27-2007 06:29 AM
http://forums.pelicanparts.com/uploa...1190901744.jpg
Factory workshop manual extract - 4, 10 and 2 o'clock
cnavarro 09-27-2007 06:44 AM
I totally forgot Wayne's suggestion for the oil ring, that's a good one John. You also mentioned on another thread not lining up the gaps with the oil return holes, another good suggestion.
HKZ Bob 09-28-2007 02:09 PM
Thank for all the help. I like V12 scetch with the 4-10-2 position.
The other point is lining up the gaps with the return holes in the 3rd oil return ring. Have you seen cases when using the 2 o'clock postion that there was an overlap of the pistons return bore and the ring gap?
Regards Bob
gigem75 09-28-2007 06:25 PM
big holes, nice and smooth, like a plasma cutter
V12man 09-29-2007 02:25 AM
HKZ Bob - that's not a sketch - thats a piece of the porsche workshop manual.
Hope it helps you though - until I searched for the drawing for you, I thought it was 9, 3, 12 - live and learn I guess - read the manual more often seems like a good idea for me now.
