Hbrand
Small leak at cyinder to head
My 1973 engine has a small leak at the top of the cylinder and the head.
I can see the black stain there and think to hear it. Still runs perfect, also on idle. Question: Did anyone tried to put a little aluminum or copper powder into the intake of the effected cylinder - while engine is running. Those tiny particles might seal the tiny leak. thanks, harold
Cheers 1982 Porsche 911SC Euro 1969 Mercedes 280SL 1956 Austin Healey 3x |
Have you checked to see if your head studs are too loose? I would check that before you dump copper in your intake runner.
Ummmmmm, I don't think the particle plan is a good choice....
cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Powered aluminum & fire don't mix.....well actually they do.... rapidly.
JPIII Early Boxster |
