2.4 MFI Heat Exchangers
Hey anyone know the difference with the heat exchangers made for carb vs MFI engines. I need some heat exchangers and there is a pair on ebay from a 70 911. Thanks
Drivers side exchanger has an additional tube that is used to connect to the MFI pump thermostat. I do not know of any other differences. Can be used on carb car. Might want to plug the tube if you don't use it.
I have a pair of MFI heat exchangers from a 70E that are coming off shortly for headers. If you need any help, you can PM me.
| All times are GMT -8. The time now is 07:27 AM. |
