-   -   What info should I obtain before the motor comes out? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/371976-what-info-should-i-obtain-before-motor-comes-out.html)
Jeff 10-14-2007 06:13 AM
My 1987 3.2 has 140,000 miles and no history. It runs strong but smokes quite a bit at start up and idle. I plan on doing a compression test and a leak down test, is there any other info I need to gather before I pull the motor? Where can I get a reasonable priced leak down tester kit?
