-   -   Rocker arm bushing source (http://forums.pelicanparts.com/911-engine-rebuilding-forum/374004-rocker-arm-bushing-source.html)
Lapkritis 03-08-2013 06:32 AM
I had a nice response typed up here and then my web browser crashed so here's the cliff notes version. Engineers- feel free to grade my response below; I'm in telecom project management by trade so I'm talking way outside my scope.
http://i458.photobucket.com/albums/q...psc97743c7.jpg
The oil channel idea - I wouldn't try it on my own. If you cut a channel down into the bearing face where the two parts meet then you will reduce the surface area between the two. The remaining surface will have higher pressure per square inch than unaltered because there is less surface to spread the load over. This could potentially cause more harm than good.
The thermal expansion causing binding idea. This doesn't hold up as the rate of expansion for brass is much higher than steel. If the part is sized correctly to match exactly the OEM dimension then the new bearing would actually grow less than the original brass under the same conditions. See coefficients of linear thermal expansion above for table of materials and values. http://www.engineeringtoolbox.com/linear-expansion-coefficients-d_95.html
I suspect the wear is due to the teflon coating wearing off which exposes the steel material. Once the coating is gone you have an increase in bearing temperature through friction which only exacerbates the thermal expansion discussed above and causes further bearing wear. Basically, once the teflon is gone the bearing is toast.
Proposed solution: increase diameter of bleed through holes and degree of taper of these holes in the outside of the rocker to catch more oil. Confirm size of bearing and fit of rocker shaft; if they're tight when cold then you're going to have a serious problem when the heat and expand into each other.
KTL 03-08-2013 08:23 AM
Frank,
Do you have any pictures of your rocker shafts? Curious to see what metal transfer you experienced. My low usage shafts show some "shadowing" where the load is placed on them. But no indication of bearing failure.
chris_seven 03-08-2013 08:24 AM
Andrew,
I have been reseaching Rocker Arm bushes for some time now and I am not confident that DU/DP and other bushes of this type are entirely suitable for refurbishing old Rocker Arms.
If you look at data provided by Glacier then the Teflon Impregnated bushes were originally designed for 'dry' operation where their characteristics are described as 'excellent'.
Once you lubricate this type of bush their performance is described as 'good'.
I don't believe that you should 'hone' this type of bush and the recommended method for obtaining the correct clearance is to adjust the shaft diameter.
Glacier make the following statement;
The burnishing or fine boring of the bore of an assembled DU bush in order to achieve a specific clearance tolerance is only permissible if a substantial reduction in performance is acceptable. Fig. 24 shows a recommended burnishing tool for the sizing of DU bushes if absolutely required.
I must say I wouldn't be confident about doing this without significant testing.
I don't think expansion is much of an issue.
The bearing is very thin so expansion will be small and the housing (the bore of the rocker) is steel and will constrain outward growth of the bronze.
Obviously the clearance and fit need to be controlled to the correct amount and the data is readily available on the GG Bearings website.
The clearance and fit of shafts and bushes is also an interesting topic and it is normal to make adjustments to shafts as this is generally easier than honing bores but this process can be carried if the bush is designed for this procedure.
The shaft tolerance of a 911 Rocker is around h7 which is not too difficult to acheive.
I think these tolerances are a bit large for DU and would prefer to see shaft tolerance of around h5 with a suitable housing size.
Surface finish is also an issue and DU needs with an Ra of = or better than 0.2 microns for mixed film or hydrodynamic operation. If the shaft is rougher than this then wear could be quite rapid.
If you compare this to the values recommended for use with a Glyco Bimetal bush, used on the standard rocker you find a recommended Ra of 0.8 to 1.6 micron. This is to ensure that the shaft surface holds the correct oil film. If the surface is smoother than this level the bush will wear due to insufficient lubrication.
My conclusion is that there are detailed significant diifferences in the design requirements for Bimetallic and DU bushes which means that the two bushes are not readily interchangable. The devil is always in the detail.
I am sure if the 'housing' (rocker arm) is dimensionally correct and the shaft designed to suit then DU or one of its improved derivatives such as DP4or DP11 would be very good but I would not be confident that they would work well with housing and shafts designed to suit Glyco or other BiMetallic bushes.
As we are just concluding the final design and manufacturing stage of our new Rocker arms and shafts we have spent some time worrying about the choice of bush material.
It was tempting to use these new materials but then we would have to sell the shaft as well as the arm and this just pushes up cost and looks a little 'opportunistic'.
We have decided to use a Glyco bush so that our new rocker will work with standard shafts.
Glyco bushes are sold in a semi-finished condition so we can precision hone them to the correct size after they have been installed.
burgermeister 03-08-2013 02:08 PM
If you alter the rocker bore or the bushing length of the roll, the press fit won't work, so that's not an option.
But I'm not a guy who got the Du bushings to work (though I did nothing except press them in), so I am probably not the right guy to converse with! :)
burgermeister 03-08-2013 02:26 PM
Kevin, unfortunately no pics of the shafts or worn bushings. It was summer, I was in a hurry, so I got the rockers rebushed (with bronze) & refaced, polished the shafts a bit, and plopped it all back together without photographing a single thing. The bushings were disposed of at the rocker refurbisher.
Based on Chris_seven's info (and since the motor is apart once again for valve guides) I have ordered all new rocker shafts, as it sounds like the polished ones are not good with the bronze bushings ...
Lapkritis 03-08-2013 02:29 PM
Re: Rocker arm bushing source
Chris - thanks for the response. Would scuffing the rocker shaft with an abrasive to return that ra be beneficial prior to install for longevity purposes? Any other suggestions?
chris_seven 03-09-2013 12:58 AM
If the bush you are showing in your photograph was a PTFE DU type bush then I am sad to say that is is completely worn out.
The guidance is that when 50% of the surface shows the bronze backing material it is 50% worn and at 70% visible bronze it needs to be replaced.
Running the bush in this condition will probably damage the shaft.
I decided that the best course of action with rockers and shafts has been not to mess with them as doing the detailed calculations of life and service factors just became too worrying.
We are just about to make a batch of 'Motorsport' style rocker shafts to complement our new rockers and at the moment we are just going to use the standard design while we test and develop some of the new ideas we have been looking at on a different thread.
We are centreless grinding the surface to the recommended Ra and we are using a sub-contractor with a Talysurf so we can correctly inspect the surface finish.
We are then going to use a Nitrotec process to surface harden the shaft to around 1000Hv.
Nitrotec is said to be oleophilic as it is slightly porous.
The cost of making these shafts even in modest quantities is so attractive it just isn't worth the risk and the time mucking around with used parts.
We can also control the tolerance of the shaft to higher level than the standard part and ensure we can optimise performance with our new rockers.
By using a Bimetallic semi-finished bush we can optimise the shaft fit into the housing and still have the correct bearing clearance to allow for temperature.
I have recently seen a video on U-Tube where the suggestion was made that it is good practice to 'stone' the OD of a used rocker shaft to remove any scoring or pick up marks and then re-use.
I have to say that I couldn't endorse this practise and any shaft that was scored I would throw away.
I looked quite deeply into both DU and DP4 bearings in the 'Du B and DP4 B' forms.
Both these materials are triple layer = PTFE/Bronze/STEEL and PTFE/BRONZE/BRONZE.
1. Burnishing or Honing to Size
Removal of 0.025mm by Burnishing reduces life by 20%
Removal of 0.025mm by Honing reduces life by 40%
Removal of 0.05mm by burnishing reduces life by 70%
Removal of 0.05mm by honing reduces life by 90%
Not great news.
The details of the materials and sizings are a bit detailed but for anyone interested were the basis of the decision not to use PTFE style bushes.
Standard Porsche Data.
Shaft Diameter 17.992 -18.000
Bore Diameter in Carrier 18.000-18.018
Clearance 0-0.026mm
Obviously if bore is at minumum and housing is at maximum it will be quite difficult to fit the shaft and damaging the surface will be quite difficult.
By centreless grinding the shaft we can easily tighten up the shaft tolerance and avoid the interference and still ensure that we have some potential to deform the end of the shafts.
We can make the shaft to an h5 tolerance and use a maximum of 17.998.
If we use DP4B bushes we would need a shaft of 17.948 - 17.966
This is about 0.001" smaller than the minimum shaft size specified by Porsche and could cause some issues in clamping the shaft into a housing with a maximum size of bore.
This part of the design is already troublesome and increasing clearances just doesn't seem wise.
To make the DP4B work it also assumes that the the housing has a diameter of 20.000 to 20.021otherwise there could be other issues.
I came to the conclusion that using a Bimetallic semi-finished bush with a honing allowance built in gave me the best scope to do the right job.
911 tweaks 03-09-2013 06:01 AM
excellent here chris...just spot on...I can't wait to see the prototypes & here the trial results...I for one am 1 of many I am sure that will buy these as they are needed these days...
you are making a correct part to address what life (time) has done to these parts...thx for sharing your engineering research which looks very promising to be a solution to this issue...
Porshaah 09-03-2013 02:33 PM
Is there a recommended hone grit size for the Glyco bushings?
TIA
chris_seven 09-04-2013 01:34 AM
We spoke with Federal Mogul but they don't provide any data or information but clearly the finish needs to be very fine and we opted for a diamond hone.
We use a two stage process with a 220 grit to remove the bulk of the material.
Final honing is then 400 grit.
Clearance is also important and as we are making shafts with a close tolerance we hone the bush to suit.
Machining is not a bad option and we used a tip radius of 0.7mm with an Approach Angle of 30 degrees and a Primary Angle of 10 degrees. Speed was 2.5 metres/second with a feed of 0.1mm per rev.
With plenty of lubrication the results were quite good. This approach was lower cost than buying a couple of diamond honing tools but quite time consuming and would possibly have generated more scrap.
You could also ream if you have a suitable reamer.
911 tweaks 09-04-2013 05:50 AM
sounds great chris...any pics a/o parts now available or is a case by case basis = you need to make parts per ea application = size them...??
docrodg 09-04-2013 08:45 AM
Could a pressure burnisher do this? I know they are used in high pressure hydraulic units to polish bores and pistons for dampers in metal stamping. I don't remember the RA acheived but it was very small, I think in the 20s, definitely under 40.
chris_seven 09-04-2013 08:55 AM
You can certainly burnish a Glacier bush, the method is shown in the Brochure for their SP material and this is relatively similar to the Glyco.
I don't have experience of burnishing so we bought the honing tools and we achieve better than 20.
HawgRyder 09-04-2013 11:36 AM
Is it possible to get the bushing too smooth?
My thinking...little depressions would hold oil...if it were too smooth and very well fitted (minimal clearance) there would be almost no oil in the gap.
Bob
chris_seven 09-04-2013 04:30 PM
Bob, I agree but it is more conventional to grind a shaft with the correct Ra to hold an oil film which is what we have done with the shafts we have made.
The grinding has been controlled and surface roughness checked.
Also the Nitrotec finish we have applied holds oil in the slightly porous surface produced by the diffusion based hardening process which should help.
The oil film thickness seems important and I believe we have the correct values.
I have seen the bushes with oil pockets which are a fairly recent development but have no practical experience with them.
It believe is difficult to size 'dimpled' bushes and it is conventional to use them 'as supplied'
The problem with this is that you have to grind the shaft to the correct size to produce the clearance. So if the bush is on the small size when fitted you would have to grind the shaft and this may reduce the degree of 'fit' into the housing which could allow shafts to walk.
We have tired to design our parts using a slightly different approach.
We have manufactured the rocker shaft to be a close fit to the bore in the cam carrier as this will provide the most reliable seal and it should lock without over tightening the bolt. We make the shaft towards the top end of the Porsche Spec and grind to a very close tolerance.
By using the Glyco semi finished bush with a honing allowance on the bearing surface we can produce not only the correct finish but the correct clearance for the shaft that we have manufactured. We used a very smooth finish on the bush.
This should give us a predictable and reliable result using conservative 'known art'.
Porshaah 09-05-2013 05:44 AM
What is the recommended hone grit size for the Glyco bushings when using OEM shafts?
TIA
chris_seven 09-05-2013 09:54 AM
Glyco/Federal Mogul don't provide any information that is the problem.
They neither recommend a grit size nor a surface finish so you need to make the engineering decisions based on experience.
I would consider 400 grit on a diamond hone as being OK.
HawgRyder 09-05-2013 03:16 PM
Chris...would there be any advantage to grooving the pin..just in the middle area where the bushing rides?
Either a straight groove or perhaps a slightly diagonal (length wise or side to side) on the bottom (bushing pressure area).
I am thinking it would spread the oil film full width on the bushing.
Bob
chris_seven 09-06-2013 12:11 AM
Bob,
I am not sure that shaft/bush wear is a major issue and I am not sure that introducing a new variable that will need testing and could cause problems is worthwhile so I have no plans to make this change.
I would be happy to make a set for you if you want to experiment. :)
Lapkritis 09-06-2013 04:34 AM
If you were to create a groove on the shaft then I would suggest parallel with the taper grooves. Otherwise you would have the harder shaft sawing on the softer bushing each time the edge worked over it if it were not parallel. Having a leading edge present under tension from the valve spring could have a windshield wiper effect on the oil film layer.
HawgRyder 09-06-2013 12:18 PM
Chris...must pass on the set for experimenting...tks anyway.
Andrew...had not thought of the wiper action....I was going by the grooves in a set of Clevite bearings we used to use in drag engines (and some circle track ones) they had a pattern to the grooves that looked like the viens in a tree leaf...a central radial groove with smaller ones radiating out in a diagonal pattern.
I just realised the those were for a rotating bearing...whereas the rockers do not rotate...they just move a slight bit in comparison.
Oh well.
Bob
docrodg 09-06-2013 12:59 PM
I am very familiar with KS Bearings as I used to inspect their quality and environmental management systems. They put out a good product and stand behind it well.
Ken911 09-06-2013 01:21 PM
Originally Posted by Lapkritis (Post 7306196)
Are these killing the rocker shafts once the coating wears?
OK so i have the engine apart For the EFI swap. I learned several things. First of all i had for a short time after market rocker shafts that walked and showed premature wear with these bushings. Those were replaced by genuine Porsche rocker shafts and run for about 30k miles in my turbo. Attached are some photos showing the coating mostly worn through which probably happened with the crappy rocker shafts. However the factory rocker shafts showed almost ZERO wear after 30 k miles. I couldn't measure any difference only a difference in the burnishing on the machined finish. So if C gar is still redoing rockers I will be sending these to him for a redo for the rebuild. I did them myself last time was less than happy with my own installation. I would definitely recommend these bushings and will use them again.
http://forums.pelicanparts.com/uploa...1378498750.jpg
http://forums.pelicanparts.com/uploa...1378498785.jpg
http://forums.pelicanparts.com/uploa...1378498824.jpg
chris_seven 09-08-2013 12:43 AM
If the bore of the housing is within specification and the shaft bolt correctly tightened there are two reasons why a shaft could walk out the carrier.
The first is that the shaft has been made too small and that there is insufficient expansion to make it grip correctly in the housing.
The second is that the wall thickness at the end of the shaft is too large so that the expansion is too low to allow the shaft too grip.
The small shaft would increase the clearance in the bush and this may affect lubrication but as these bushes tend to operate in a 'mixed-mode' this seems an unlikely reason for accelerated wear of the type shown.
If the shaft is the correct size then the clearance in a Permaglide/DU type bush may be too low and this would certainly accelerate wear of the PFTE/bronze layer and would result in a more general wear.
Tom_in_NH 09-11-2013 01:27 PM
Ken,
I'm about to do a top end on my 3.0 with 80K miles on it due to a broken stud, and will likely need to have shafts polished and rockers rebuilt/rebushed. Who is C gar? Does he have a company name?
Chris, if I was in the UK, I'd definitely use you!
Thanks, Tom
burgermeister 09-11-2013 01:42 PM
Tom,
Cgarr is user cgarr on Pelican. He's located in Michigan. Just PM him (search for a post & click on his name to send a PM).
Ken911 09-11-2013 03:19 PM
What he said
jtsilverfox 09-19-2013 03:11 PM
Guys: Interesting reading. I've got a 69 911E that I've recently (finally) got all apart. 6 of my 12 arms and their respective shafts are badly scored. Is it possible to bore out the arms and put bushings in them? One shop I talked to said that nobody around here (south bay area) does it.
http://forums.pelicanparts.com/uploa...1379628656.jpg
burgermeister 09-19-2013 03:32 PM
I'd be nervous boring that out. You will be reducing the thickness of the rocker arm by 1mm right around the bushing, which may or may not be sufficient for infinite fatigue life. Just eyecrometering, it would appear the later bushed arms kept the same thickness of material as your arm has, which suggests Porsche had similar worries.
chris_seven 09-20-2013 02:43 AM
How badly marked is the bore of the rocker arm?
The 906/RSR/935 Rocker Arms didn't have bushes and ran on a specially treated rocker shaft that had a coating applied.
We have re-manufactured this type of shaft with a hard layer (1000 HV). The technique we have used also produces and oleophilic surface so holds an oil film.
http://i197.photobucket.com/albums/a...ps557932b1.jpg
If you can lightly hone the bore of the arm and keep the diameter within spec these shafts may help.
jtsilverfox 10-30-2013 08:04 AM
Thanks guys. I tried turning down a couple of the shafts and realized the amount I'd have to do would create way to much clearance. Not to mention the hardening that chris_seven mentions. Didn't even try the rockers. So, I'm now looking for some good used (i.e., inexpensive) replacements.
Porshaah 10-31-2013 04:06 AM
Originally Posted by kanna (Post 3551877)
Anyone have a source for 911 rocker arm bushings( bearings)?
These look like they'll fit a 3.6l 964 after being honed to size?
******** Parts Catalog
chris_seven 10-31-2013 06:19 AM
They will also need the oil feed hole machining as they are delivered as a plain bush without this hole.
Porshaah 03-05-2014 08:29 AM
A couple weeks after placing the order with ********, I was informed that the Glyco bushings were unavailable, but not discontinued. All calls to Federal Mogul Europe, the distributor of the these bearings, went unanswered. Anyone know of another source for these bearings, preferably in North America?
chris_seven 03-05-2014 10:13 AM
We have just ordered 250 and they are due to be delivered from Belgium in around 10 days but we are in the UK so maybe of no help.
New adjustable forged rocker just back from superfinishing.
http://i197.photobucket.com/albums/a...psc4aba264.jpg
chris_seven 03-24-2014 11:43 AM
http://i197.photobucket.com/albums/a...ps1b724743.jpg
The above Rocker arm after surface treatment.
Hardness is just below 1000HV (measured using a MicroVickers Hardness Tester.
This is equivalent to around 70 RockwellC and should be relatively wear resistant.
Hard Chrome would be similar in the 'As Plated' condition but if the chrome were ground after plating hardness would reduce to around 850HV.
cgarr 03-24-2014 11:52 AM
Looks most excellent! What did you come up with surface hardness of a stock factory mid 80's rocker? Best I could tell was 62 to 65?
chris_seven 03-25-2014 12:19 AM
Craig,
I haven't tested the stock Cast Steel Rocker but next time I visit my Heat Treatment Company I will take one with me as they have a high quality and calibrated Mirco Vickers machine.
If you can access a Superficial Rockwell machine with a 30N force you may have some success but 62 to 65 sounds about right.
We tested some hard chrome rockers and had values between 850 and 900HV.
The hard chroming company that we spoke to does produce coatings with a hardness of around 1000 to 1100HV but these are very thin layers used on Ducati Rockers.
These engines are desmodromic so have very low spring forces and we didn't think that this type of coating would be adequate for 911 engines using 906 style cam profiles and valve springs.
By increasing the plating thickness the pad on the rocker would need to be ground and this process would reduce the hardness of the chrome to the level we measured.
The coating we have used is also 'oleophilic' and will help with boundary conditions and should generally improve the wear behaviour of both the rocker and the cam.
