Engine Case Cleaning
Ive seen many rebuild threads where people show pictures of cases that they have obviously spent a lot of time cleaning up and making look like they have just left the factory. What methods do people use? Are there chemicals that can help? or is it all down to elbo grease and hard graft.
I have a case in need of some serious TLC and need some ideas how to go about it. Steve |
Seems like I spent 16 hours cleaning my last case - it was really crusty and dirty. Supplies:
-razor blades - to remove old sealants. careful careful, don't nick sealing surfaces. -Scotchbrite pads (green) for scrubbing inside and outside case surfaces -brake cleaner for spraying out holes and piston squirters -acetone for g/p cleaning -rifle bore brushes, various sizes for thru-bolt bores and other bores -wire brushes I'd also love to hear tricks from anyone else as I have another build starting next month. |
http://forums.pelicanparts.com/uploa...1181348799.jpg
This case was hot-tanked and then tumbled in ceramic media and then all the oil passage plugs were removed, the oil passages thoroughly cleaned and then the plugs reinserted. It will receive another cleaning by me personally prior to final assembly. |
Steve |
Steve, all fair questions. I did not note any dimensional changes from the process.
John did the case show have piston squirters? if so would these need removing te ensure no media is trapped behind?
Steve |
Steve,
The old aluminum cases, of which mine is one, did not come from the factory with piston squirters. These were added in 1971 to the mag cases. Squirters were installed in my case although I'm not sure at what point in the process- probably after the tumbling and before the cleaning just to make sure any chips got blown out of the oil passage to which the drillings for the squirters connect. |
I used a dry ice blaster to clean mine. We rented one at work so it didn't cost me anything but there are people out there who dry ice blast for a living. It cleaned my 3.0 case to look brand new without putting one nick or ding in it. And the stuff just evaporates within seconds. I was impressed.
Sounds promising, no abrasive to clog you oil ways. Do you have nay pics of the results?
steve |
I will take some this weekend.
Well the end result certainly looks well, do you have any before pics?
Steve |
no I don't but it had a ton of oil, dirt, and grease on it. I tried using degreasers with brushing but it would have taken me forever. I even dipped one half of the case in a parts washer and it only removed some of the oil not the hard black stuff. If I didn't ice blast it I would have had to get the case professionally cleaned.
As far as cleaning my case, I used a red shop cloth, with mineral spirits. I then used a mild detergent, rinsed with water, blow dryed with shop air. Then, I used about 400 red shop towels and about 2 to 3 cans of the big Mothers Al polish (jewelers rouge), and the buffed to a nice shine. I cleaned all of the oil passages, etc... I estimate that I have between 160 to 180 hours worth of time into the case..... but when you dont have enough money to build the motor right then.... it was time well spent as it kept me interested in the project.....
http://members.cox.net/turbobrat930/DSCN0532.JPG http://members.cox.net/turbobrat930/dscn0553a.JPG http://members.cox.net/turbobrat930/dscn0612a.JPG |
That looks perfect.
Lawd, the only people who have this kind of time are either in jail, very single, in a monastery or stuck in the outback somewhere! :confused:
Looks great tho. SmileWavy |
beautiful,
did you spray it with scotchguard? hee hee bob |
Ok, rather than start a new thread I'll just piggyback on this one. I've been cleaning my '88 3.2 case thoroughly but there is still a faint tan colored anodized look on the inside that does not seem to want to come off no matter what I do. I've even used a brass brush and it barely affects it. Am I safe in closing it back up? As I said, this "almost" looks like a stain or anodizing.
TIA |
I am guessing that the faint tan color that you are describing is what I would call "oil stain".... I really dont think it will hurt at all...BUT, if you want it gone....take some Mothers brand Aluminum polish....dab a small bit onto a shop cloth..and run on a small spot. The white polish should turn very black within about a minutes worth of polishing.... clean it off...and buff The oil stain should be gone. I would caution you however... if you use the polish, you need to be DARN sure you get every last bit of polish out of the case before reassembly...... after doing the whole inside of the case...was, wash, and wash it again!!!!! |
Turbobrat... did you really do that by hand or did you use a dremel with polishing wheel. I can't get anywhere near that with just a red cloth. I usually throw my polishing wheel on the bench grinder and get things pretty good but nowhere near that. What is your secret?
By hand...thats all... I was saving up the money to rebuild the motor...and was getting pissed that it was taking so long to save...not to mention the cost of the parts... So, I kept busy by cleaning the case. I sat on the sofa...watched some tv...and just polished away!!! I even had to stop for a few weeks, as I had rubbed a few blisters in my fingers..LOL I still have the 3 to 400 red shop rags in a garbage bag to prove it. I need to clean them..but the wife said...NOT IN MY WASHER YOUR NOT!!!! So, havent taken care of it yet.... just red shop rags, Mothers AL polish...time, and effort...thats all....
Whoa, you win the engine case cleaning prize, hands down. :eek:
It makes me sad thinking about the car that engine goes into being driven. I mean, really, there might be some crud from the road that gets near that beautiful work of art, or grease, or brake dust, or, who knows, but it's going to get dirty somehow, and that is a shame! |
Turbobrat930,
Consider using Zoop Seal to fill in the pores of the metal, this will prevent the case from oxidizing for a couple of years. Would be a shame to see all that effort prematurely fade, but as an old metallurgist once said, "once the Bauxite leaves the mine it spends every minute trying to go back." Beautiful work. |
Thanks for the compliments guys.... I am happy on how it turned out... I know it wont stay pretty for ever...but like I said... I needed something to do while saving money for the rebuild..
John, I am buying some zoopseal for a set of polished wheels...so I will apply it to the case as well. |
| All times are GMT -8. The time now is 02:52 PM. |
