abit off center
cgarr's Avatar
Oil galley plug sealer
Pulling a 2.7 mag case down for pins, line bore etc and found when removing the oil galley plugs there is a lot of factory brown sealer in the passages. Some is still in tact in the form of large droplets and it chips off very easy.. Anyone else find lots of sealer in these galleys too?
______________________
Craig
G2Performance
Old 12-01-2007, 04:41 PM
Nitrometano's Avatar
When I cleaned mine, I dont know if that was sealer, but I found that black stuff sticky on the walls of the orifice. I use a piece of stainless steel wire to remove the most "sealer" that I can. Then I used a lot of carb cleaner and compressed air to clean the passajes. Also I found grey silicone on the engine thru bolts holes, oil pump o-rings, oil cooler o-rings, cam towers to cylinder head surface and in the #8 nose bearing o-ring.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 12-08-2007, 07:02 AM
1972 911T
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I have a set of gun cleaning rods that I have used over the years.
They have both brass and stainless wires on them, and they do a very good job if you size them to the hole closely.
Also, I never use press in plugs after cleaning, always tap (thread) and use a screw-in plug (my paranoia).
Bob
Bob Hutson
Old 12-08-2007, 08:15 AM
Bob, were you get the screw-in plug that you are talking about?
1972 911T
Old 12-08-2007, 08:47 AM
