-   -   Three Bond 1194 & Squeeze Out (http://forums.pelicanparts.com/911-engine-rebuilding-forum/374599-three-bond-1194-squeeze-out.html)
MatthewBrum 10-29-2007 06:09 AM
I assembled my case last night using three bond 1194 around the case perimeter. I thought I put enough on but I got very little squeeze out and it seemed the 1194 got tacky very fast. Is this normal? I got everything torqued down within 1/2 hour of application. In some areas of the case I do not see squeeze out on the outside, but I do see a little bead on the inside. Some reassurance would be nice because I know I spread it all over the sealing surfaces.
