-   -   starting my build plan for a 3.6L 964 motor (http://forums.pelicanparts.com/911-engine-rebuilding-forum/375488-starting-my-build-plan-3-6l-964-motor.html)
edbaus 11-03-2007 04:30 PM
Hi,
I am starting to think about getting my ducks in a row for building a 3.6L 964 motor.
It is an early motor, so I assume that I will be needing to take care of the cylinder to head sealing issues.
Also, should I get it balanced.
What else (other than normal valve guide replacement and other replacement parts) should I be thinking about for this motor. I am looking for a fairly stock rebuild. The motor will be run by an electromotive setup, so I will be getting rid of the twin distributor and any of the motronic stuff.
Ed
