-   -   Anyway to idenitify a MFI spacecam? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/375808-anyway-idenitify-mfi-spacecam.html)
rvanderpyl 11-05-2007 05:47 PM
I just bought a complete MFI system which the guy selling claims was on a 2.4T (confirmed by the pump number) which had been rebuilt and modified to a 2.7 with S cams by Stoddard. Anyway to confirm this when I get the parts?
304065 11-06-2007 12:28 AM
not externally without a volume test unless gus has records
rvanderpyl 11-06-2007 07:58 AM
Do you have a procedure and spec's for a volume test? I assume rotate pump at x revoultions should produce y volume in z time from one injector?
304065 11-06-2007 10:08 AM
Procedure is probably in the MFI repair instructions. . . I don't know what the specifications are, certainly Gus has them but he might not let them out. Would be expressed as cc per number of revolutions. This may help, for the 911E cam. . . how's your German?
http://forums.pelicanparts.com/uploa...1194372475.jpg
rvanderpyl 11-06-2007 06:57 PM
Note 3 seems to indicate that each cam has a different number stamped on it. Maybe that can be used to identify the type.
304065 11-07-2007 06:14 AM
Yes, once you have the pump apart.
rvanderpyl 11-07-2007 04:38 PM
Ey, there's the rub isn't it. :)
304065 11-07-2007 06:00 PM
Aye: the best-laid schemes o' mice an' men /gang aft agley
