Less brakes, more gas!
euro911sc's Avatar
Did you blow a case or have a blown case in your shop? I need your Studs!
I had 3 very corroded case perimeter studs that needed to be replaced. I ordered from Porsche and got the wrong ones... All the other perimeter studs I ordered were correct so go figure... 4 months later I'm still trying to get the issue resolved with them so I've decided to try a new route...
If you blew a case and can pull some working examples of the studs in the red box below I would be happy to pay you for them!!
I need 3. They are all 8mm x 78mm (93mm total length) Part number: N-014-432-4-OEM
I need these to start the case assy.
Thanks all!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 11-05-2007, 10:02 AM
MBEngineering's Avatar
HI euro911sc
PM me your shipping Add' and I will stick them AIR mail to you , as I have a SC case in bits hear.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 11-05-2007, 10:09 AM
Check if this mcmaster carr p/n works; Part Number: 93275A033 Part Number: 93210A033
one is equal length threads the other is unequal, it might be quicker to get.
Old 11-05-2007, 12:21 PM
euro911sc's Avatar
Mike,
sent you a PM (though it didn't exactly say 'Done' so if you don't get one let me know)
Matthew,
I've been all over the i-net, but I'll look into it for sure. Grainger/MSC/Others did not make it. Believe it or not, but ACE Hardware came the closest! Who knew...
Thanks a bunch gents!
-Michael
Michael
'13 Cayenne GTS
Old 11-05-2007, 12:33 PM
HI Michael
"Mike,
sent you a PM (though it didn't exactly say 'Done' so if you don't get one let me know)"
no did not receive any PM's, will the studs from this case be OK for you,
hope to hear from you later I will package the studs up ready to go, to today.
regards mike
Regards mike
Old 11-06-2007, 12:37 AM
euro911sc's Avatar
Awesome, Mike. Those should be perfect. PM re-sent
Wow, blew right through the top of the case! Did the projectile go through the deck lid or stop at the Airbox?
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 11-06-2007, 06:22 AM
HI euro911sc
studs on there way air mail.
regards mike
Regards mike
Old 11-07-2007, 02:52 AM
