Question about Euro Carrera 3.2 DME
Can some of you engine gurus explain to me exactly how the euro DME controls the decel function (rapidly dropping RPMs)? I drove a friend's car at an autocross on Sunday that had a very disconcerting quirk that I have never experienced before. When threshold braking from high RPMs in second gear, the engine would seem to "stall" or cut out at a certain point as the revs dropped. The exhaust note would change from a rapidly lowering "burble" to more of a "hum", as if the engine had stopped firing, and I could feel the rate of deceleration increase as the dead engine pulled the rear wheel rotation down another notch--as if I had suddenly dialed in more rear brake bias.
I talked to one of the local mechanics who told me that this is normal for a DME engine--that there is a fuel cut-off at 1700 RPM on rapid decel. Is that correct? How is that signalled to the engine and why is it necessary? For economy, or to prevent fuel overrun or something? That may be fine for a street car, but is there a work-around to prevent this in a race car setup? You can actually hear this happening when just free-revving the car at a standstill--the engine note changes at a certain point during the decel cycle, and the revs will drop more rapidly, to below normal idle speed, and then bounce back up to idle as the fuel comes back on. Is this fuel cut contained in the chip programming (fuel maps) or is it controlled by the manifold pressure/RPM and a microswitch that shuts off the fuel pump or something? I know little or nothing about Bosch DME functions, as I have never owned an engine like this. When this happened on course, if I was trailbraking into a corner, it was sufficient to upset the car by breaking the rear tires loose, and I would have instant oversteer. I basically had to drive around this by abandoning my normal trailbraking and braking earlier, in a straight line, and being back on the throttle slightly before turning in, to make sure that it wouldn't happen on my way to the apex. Even braking in a straight line, some cornerworkers told me they could see the rear wheels locking up momentarily at times. The car has stock brakes (S calipers in front, M in the rear) so this added rear bias is coming from the engine drag when it cuts out. The engine is in a lightened '74 RS-bodied car running 245F/275R Kumho Victoracers, so this is not a stock Carrera, BTW. Thanks in advance for any explanations, TT |
I would say it is probably in the fuel maps for two main reasons fuel economy and emissions. You could probably have it tuned out of the software with the right chip programming.
They cut fuel ABOVE ~1700 rpms on closed throttle. I don't think that's limited to the euro models.
I wasn't looking at the tach at all on this busy autox course, just going by ear, but when I ran this engine to 6,000 or so in second gear and then lifted and went to heavy braking, it would decelerate normally for the first few seconds in the brake zone, and then seem to die when the RPMs were somewhere below 3,000, I'm guessing, and not always consistently in the same range, I don't think. This is when the sound changed and the extra engine compression braking would start. When I got back on the gas, it would pick right up again. It was almost like someone turned off the key. If I was already turning in when it happened, it made for very unpredictable handling, to say the least. TT |
It might not cut the fuel totally off but lengthen the injector pulse. Are you sure that the airflow sensor just didn't have a bad spot on it. It would be interesting to figure which input is used for the Idle Air Control valve if it is the micro switch for closed throttle or the TPS to show throttle plate position.If can figure that out you might be able to figure away to trick the DME not to do the fuel cutoff.
On decel (idle microswitch activated) fuel injectors are shut off until the rpms drop down to about 1050, when the injectors come back on. This is for fuel economy and emissions. The turn on point can be altered, to eliminated altogether in the programming. Turning it off is good for a more rapid warm up of the engine in cold weather situations, or in racing for slightly improved throttle response. The drawback is a 10% reduction in fuel efficiency.
HI TT
some paperwork for you to check on your car and the DME unit, which may help your car for the track days. http://forums.pelicanparts.com/uploa...1194963763.jpg http://forums.pelicanparts.com/uploa...1194963790.jpg http://forums.pelicanparts.com/uploa...1194963818.jpg http://forums.pelicanparts.com/uploa...1194963845.jpg for your educational purpose. regards mike |
HI just found this also
http://forums.pelicanparts.com/uploa...1194964416.jpg this info' is for "euro" cars. regards mike |
Having talked with the owner about it some more, I have additional info about the engine. It is not a stock 3.2--it has been modified to a 3.4 with JE pistons (10.3:1), with remachined and plated 98mm barrels by EBS, and 964 cams. The pistons are domed with machined valve clearance reliefs, as the plan was to eventually put carbs and "S" cams on it, but for the time being, the stock induction was retained. It spent a lot of time on the dyno at a local EFI shop having a custom chip programmed for it, but I don't think the kind of "real-world" race usage I experienced was anticipated or accounted for. I can't help but think it is going too lean on decel to fire the mixture at some point, and it is going dead at times--at least that is what it feels like. My only experience with EFI has been an SDS system on a Honda S2000 engine, so I know little to nothing about the Bosch Motronics. All my 911s have been either CIS or carbs so far. The SDS system used a TPS and MAP sensor to control mixture, along with a crank position sensor for timing--there was no idle microswitch. Why does the Motronics use this? There is no 02 sensor on this car, but there is a port for one in the headers, so I am thinking of hooking up my LM-1 wideband A/F sensor to it to see what exactly is happening. How lean should the mixture be going on decel? What A/F ratio would be too high to support combustion anymore? The owner wants me to co-drive the car with him, but this particular quirk makes the handling so evil it is impossible to really attack the course as I am used to doing, and it is not as much fun for me as my own cars. Thx, TT |
TT |
The mixture on decel with the idle switch activated will be basically nonexistent, as there is no fuel being burnt. The LM-1 will read open air as the engine is now effectively just pumping air through the exhaust system. The DME numbers indicate that it is a brain from a 87-89 Carrera U.S car. The RX is not OEM, and was probably added by a DME repair place. Since it was remapped as you said, this won't tell you anything about how it was mapped. The only way to tell is to dump the code and read it to determine the mapping. |
TT |
I will have to inspect the throttle body and linkage action and then put the A/F meter on it to see when it goes totally lean in the decel cycle. Thanks for all the help. I've certainly learned a thing or two. TT |
| All times are GMT -8. The time now is 07:03 PM. |
