-   -   Leak Down, what should I look for? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/377349-leak-down-what-should-i-look.html)
C-Pierce 11-14-2007 08:08 AM
I will be doing a leak down on my car tomorrow (freshly rebuilt 3k miles ago), it stil smokes intermitently that is why. 2.7CIS stock re ringed cylinders not replaced.
I am wondering what I should be looing for and what should throw a red flag. any tech articles written on this subject that anyone knows about?
thanks
Chris
2.7RACER 11-14-2007 08:38 PM
Do a compression check first.
It's possible the rings haven't seated.
If the compression is low anywhere, spray in some oil, I use WD-40, then recheck.
If the compression rises significantly after spraying oil, the problem is a worn out cylinder, or a need to run a grape hone lightly through the cylinders.
If the compression is fine, likely a valve guide issue.
Ask me how I know.
Nikasil or Alusil?
C-Pierce 11-14-2007 08:43 PM
I did have the heads re-built How can I tell what the problem is?
Chris
2.7RACER 11-14-2007 08:52 PM
Chris,
"If the compression rises significantly after spraying oil, the problem is a worn out cylinder, or a need to run a grape hone lightly through the cylinders."
Simply changing rings usually do not reseal properly.
