-   -   3.2 build progress-it looks like an engine again... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/377392-3-2-build-progress-looks-like-engine-again.html)
efhughes3 11-14-2007 12:21 PM
Got the heads on the other side today. I was a little quicker than the other side-particularly since I forgot to put the cooling tin on. I removed the entire head assembly to remove the tubes so I could get the tin on. Bonehead mistake.
Oops, forgot something:
http://forums.pelicanparts.com/uploa...1195071425.jpg
Fixed-no harm, no foul:
http://forums.pelicanparts.com/uploa...1195071474.jpg
Sporting some of the goodies, I can't wait until everything goes on for real:
http://forums.pelicanparts.com/uploa...1195071586.jpg
http://forums.pelicanparts.com/uploa...1195071626.jpg
That'll be it for a few days. Off to SoCal tomorrow to look at houses. Next week: CAM TIMING :eek::eek:
gigem75 11-14-2007 04:31 PM
cam timing, piece of cake
looks great!
efhughes3 11-14-2007 04:52 PM
looks great!
I hope so, it is just one of those unknowns, the last "big hurdle"....I cleaned all of my cam tensioners, idlers, sprockets and such in preparation for next week. After that, it seems like the main thing is remembering to put all of the right stuff on in the right order. I sure have a lot of parts still to go back on. I hope I took enough pictures! :D
It wasn't so long ago that I thought simply taking the engine out was a big deal...
Brother 11-14-2007 05:13 PM
I really like the color choice. What color is your shroud?
Is there another thread with the particulars of the build? I just started thinking 911's again.
dtw 11-14-2007 05:15 PM
Cam timing: grossly over-hyped. If you 'get' what's going on, you'll have no problem. Looking very nice so far, good work. All downhill from here!
efhughes3 11-14-2007 05:19 PM
I went to Hobby Lobby the other day to get a Testor's paint pen to do the red on the valve covers. They also had blank inkjet decal paper....
I downloaded the Porsche font and printed out a PORSCHE decal to go on the fan housing strap. It is the same titanium ceramic coating as the fan, and I think it needs a little dressing up. While I was at it, I printed another decal to match, we'll see if it can go somewhere under the bonnet. :cool:
http://forums.pelicanparts.com/uploa...1195089529.jpg
efhughes3 11-14-2007 05:25 PM
Hi Paul, it's about time you came to your senses....the shroud is black. I've been all over the map on posting, I should've stuck with one thread. Here are the quick details:
Case cleaned and checked for bore, oil galleys, squirters, etc.
Crank mag'd, cleaned and micropolished
Heads rebuilt, new exh valves, twin plugged , racing springs, Ti retainers
P's and C's inspected, and are well within spec, being reused
Rods rebushed and resized
Rockers rebushed and refurbed
Cams ground to DR Camshafts DC19 profile
Cam towers inspected, replumbed and cleaned
New main, rod and intermediate bearings
ARP rod bolts
Supertec head studs
Wrightwood Racing viton gasket set
Rebuilt injectors
Cleaned, leak tested & repaired engine-mounted oil cooler
New: rings, chains, ramps, oil return tubes, case hardware, oil relief valve hardware, rocker hardware & seals, alternator, cam lines, etc, etc
Misc Cad plating and powder coating
My clutch and flywheel are only about 2 years/5000 miles old, so I'm working with them The total of all of this will be close to what the car cost me originally.
zbph10 11-14-2007 06:47 PM
NICE JOB, looks very familiar. I was in the same place you were last winter.
Here's mine completed
http://forums.pelicanparts.com/uploa...1195093928.jpg
Cam timing is a piece of cake once you get your arms around it and have the proper tools. Do you have the Bentley manuals?
I'm surprised to hear you have as much into your motor as the car originally, I think I had about $4K into the rebuild.
My clutch was fairly new but I still replaced the TO and pilot bearings and updated to the new clutch release fork
Good luck
efhughes3 11-14-2007 07:15 PM
I've got all the proper tools as well as Bentley, Factory, Wayne's book, etc. Its all in my mind. I know that once I get into it, the project isn't beyond my capability.
I'm not sure what all you did for $4K? Other than reusing my pistons and cylinders, I've replaced or rehabbed about everything in my engine. Going to Aasco springs, Ti retainers, all new head stud hardware, ARP rod bolts and machining can add up pretty quickly. I'd say $4K is on the low end of costs I've seen, and mine's probably a bit more than the average.
It's all relative, I bought my car for a very reasonable cost.
Jeff Alton 11-14-2007 09:13 PM
Looking good Ed! I have forgot those same pesky black parts before too!!
I like the decal you made! Cool.
Cheers
Brother 11-14-2007 10:07 PM
Nice. So you are sticking with the stock compression ratio or are you bumping it up a bit? New chip?
What precipitated the rebuild - breakage or boredom?
efhughes3 11-15-2007 05:59 AM
Stock compression, I'm sticking with my Steve W chip, he thinks I'm ok for now. When we get to California next year, I'm looking at having him do a custom setup.
The reason? Hmmm....I think it was the nut behind the wheel. I was coming out of Richochet @ MSR-I was passing someone, and had a Cup Car on my tail-pulled her into 2nd instead of 4th. The exhaust valves protested in anger.
911 tweaks 11-15-2007 07:05 AM
Hi Ed, YOUR ENGINE LOOKS GREAT!!!!!!!
I am sure you posted this, however, what is the finish~process you did on the fan ring and top alum valve covers?
Thanks, Bob
Brother 11-15-2007 07:10 AM
Well, well. I'm moving to California next summer too. I'll be up north of Sacramento.
I bet that missed shift was a serious "OH $hit" moment.
How do you expect the cam profile to change the driving characteristics?
tsiegwart 11-15-2007 02:31 PM
question
Ed, thanks for the thread!! I've got a 3.2 that someday I'll do a rebuild on myself.
I have a question for you.
I've heard that dissasembling and re-assembling the top end and FI system are "%80 of the effort" (ie, you might as well split the case if you do a top end job). Did you find that to be the case? How hard was re-assemplying the crank, intermediate shaft and the case?
Thanks again.
efhughes3 11-19-2007 02:59 PM
Thanks, Bob
It is a ceramic coating recommended for Magnesium by my powder coater. I did the valve covers to match the fan.
More power? :D A little better from mid into top end...
Thanks again.
I'd say that the biggest stress in that area was the sealing of the case, but it wasn't that big of a deal. The rods, bearings and such were pretty simple. If I hadn't stretched rod bolts and had to open my bottom end, I think it would've been fine. But even at that, I think it would be crazy to tear down a 130K mile motor, spend several thousand $ on it, and not do the bottom end.
efhughes3 11-19-2007 03:05 PM
I chunked away at it today. I got the chain cases on, the cams lubed and in, and the timing chain sprockets on. Tomorrow is the "day of the cams". I'll time them, finally getting to use the tools Jeff Alton sent me in April or May...
http://forums.pelicanparts.com/uploa...1195513301.jpg
http://forums.pelicanparts.com/uploa...1195513330.jpg
http://forums.pelicanparts.com/uploa...1195513363.jpg
Speaking of Jeff, he called it correctly when he noted I'll have to machine my LH lower valve cover a bit to clear the spark plug boot.
http://forums.pelicanparts.com/uploa...1195513475.jpg
I also have to open up the casting on the RH chain box.
http://forums.pelicanparts.com/uploa...1195513527.jpg
BReyes 11-20-2007 09:31 PM
Awesome- Being able to look behind the rebuild - back in the drivers seat!
Giving you some moral support for the cam timing!
efhughes3 11-21-2007 06:28 AM
Thanks Bernard! After a bit of a fight yesterday, I got the cams timed. See this thread for the details:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/378452-stuck-cam-timing-issue-me.html#post3600411
It's really coming together now. I'm going to run and pick up a few more parts today, so that I'll have it all at my fingertips, based on progress this weekend:
Rebuilt Alternator, Spark Plugs, THREE oil filters, new fan belt, etc.
Plus, I'm going to go to Lowes and get a couple of 5/8 OD X 1/2 ID bronze bushings to make the safety collars for the pressure tensioners.
I'm going to take a day off today, and get back at it Friday:
1. Piston-Valve clearance check
2. Balance of rockers-install and adjust
3. Cam case covers-install
4. Install my freshly rebuilt oil cooler
This will give me a complete longblock for the first time in 7 months. Then, Saturday and Sunday comes the fun part of remembering how my injection went together, and installing it as well as shroud, exhaust, etc. We'll see how far I get.
http://forums.pelicanparts.com/uploa...1195655316.jpg
eapcpa 11-21-2007 07:45 AM
Very nice work!! It feels great to get things together after a long time but you are really paying attention to details.
KTL 11-21-2007 10:05 AM
A bit of advice on adjusting your valves when you get the cams and rockers installed........... Set the clearance and then rotate the engine, check/adjust again and check adjust again. Reason being, when you goop up the cam and rocker pad with assembly lube, it can affect your valve clearances very easily. As you rotate the engine, the rocker will wipe off the lube as it's bearing on the cam lobe and the clearance opens up.
My engine was quite noisy when I first fired it up and broke it in. The valves were VERY loose. But don't get me wrong, i'm a notorioulsy sucky valve adjuster. So maybe i'm being too concerned about my perceived thing to watch out for.
efhughes3 11-21-2007 03:43 PM
Thank you! It feels great to know that I'm getting close. Not to mention, the pain in my wallet is pretty much over...
That make perfect sense Kevin, thanks for the tip.
gtc 12-11-2007 03:20 PM
I am very interested to hear more about this. Do you happen to know the name of the coating or process? Were both the fan and the housing treated this way? Could you post or send me the name of your Powder Coater so I could ask them about it?
Thanks so much,
efhughes3 12-11-2007 04:39 PM
Thanks so much,
He just called it ceramic coating. My fan and shroud were done this way. The place is Specialized Performance Coatings in Arlington, TX. Michael Tomlinson is the owner. 817-274-1947
gtc 12-11-2007 05:03 PM
Thanks. I wanted to powdercoat my fan and housing, but I've had people tell me that even powdercoating won't resist chipping. This sounds like it could be the end-all of fan coatings for me.
James Shoffit 12-13-2007 08:57 PM
Ed, I'm scared... I don't have valve spring tools, or crow foot whatevers, or piston ring compressors - should I just let a professional handle my 3.0 rebuild ?
efhughes3 12-13-2007 09:30 PM
I have a ring compressor and some mechanical tensioners that work well for cam timing. You're welcome to borrow them. I also have some homemade copper cylinder hold downs.
I've already loaned out my stand and yoke, but other than that, it was all tools on hand except for the cam holder which I just shipped back to a buddy I borrowed it from. You can get the cam nuts off (should be able to) with an impact wrench for tear down, so you won't need the holder until cam timing time. Maybe Rick Randall has one locally?
My heads were shipped complete to Ollie's in Calif for rebuild, so I didn't disassemble them.
Let me know if you need the goodies.
Jeff Alton 12-13-2007 10:47 PM
Ed, got them today, thanks!!
The SC cam uses a different tool, but I can ship my spare "Z" block back if James needs it.
cheers
hcoles 12-14-2007 07:05 AM
Ed, great job....we are gearing up to rebuild a 3.2 here. Maybe I missed it... how did you get the case/etc. so clean? Thanks.
James Shoffit 12-14-2007 07:33 AM
...I can ship my spare "Z" block back if James needs it.
cheers
I wish I could just come get it from you, Jeff :) Normally this time of year I am planning my week in Whistler, where we fly into YVR and drive up. But not this year - wife wants to go to Paris, so there you have that. If we do go to Whistler, it will be fall of 08.
I am pretty sure I can get any tools I need locally. Rick Randall has nearly everything, I think, and he doesn't live that far from me. My main need is the stand and yoke, which I am probably going to split with another guy here that does his own SC engines. I don't mind paying for it, I just don't want to store it. I have a tiny 2 car garage, and 2 SCs in it, so no extra room :) (but a full garage is a happy garage).
Ok, you guys have bolstered my spirits... I'll grab the camera and head down to the garage soon :)
efhughes3 12-14-2007 08:28 AM
The case did get hot tanked before inspection, but it had several hours of me scrubbing as well. I don't know how many cans of brake cleaner I went thru, literally 40 I bet...
