-   -   92 p/c's for my 90 c2 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/377690-92-p-cs-my-90-c2.html)
drola 11-15-2007 09:17 PM
i have found a set of low mileage 1992 p/c's that i'm thinking about for my 90 c2 which have the sealing ring groove. if i were to use these on my rebuild, do i have to machine my heads to accept the sealing rings?
any pros / cons to doing this?
otherwise i will have to machine the cylinders and heads i already have.
Steve@Rennsport 11-15-2007 11:00 PM
Yessir, you will need to machine your heads for the later sealing rings.
Properly done, its a very robust repair.
