Locating Z1
I am trying to adjust the valves on my 3.2 engine BUT the Z1 ident is hidden behind my AC pulley. I see 4 notches on the crank pulley. I also know the pulley rotates clockwise when looking forward. Is the Z1 notch located by the 2 notches?? And which notch?? I am not sure even with Bently manual. HHHelp.:confused:
it's the left notch when you see the two notches close together.
on mine the Z1 notch is the one with two notches, one on each side of the v groove if you are looking down on the pulley. You can mark it using a toothpick dipped in white paint.
Thank you. :)
munchovie |
I couldn't have done it without the help of all the little people behind the scenes that never get the credit they deserve. :D
| All times are GMT -8. The time now is 01:41 AM. |
