1972_911T's Avatar
Piston Ring Side Clearance
When measuring ring side clearance is the wear limit a maximum allowed side clearance or is it the factory clearance + the 0.2mm wear limit.
For example in the book it states the factory spec of an SC top ring is 0.07-0.10 with a wear limit of 0.2 so is the maximum allowed clearance 0.2 or 0.1 + 0.2 wear limit hence 0.3mm?
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 11-25-2007, 10:11 AM
Factory spec is .01mm or 0.004".
If the wear limit is .02mm, that's 0.008", that's the wear limit - pretty loose and very generous, IMHO. For longevity, I would go with .01mm as a borderline max.
Sherwood
Old 11-25-2007, 02:18 PM
1972_911T's Avatar
Sherwood
The rebuild book states the factory spec as 0.07 to 0.1mm not 0.01 and the wear as 0.2 not 0.02 is the book wrong? 0.01mm is very tight ??
1972 911t RS Styled
Old 11-25-2007, 02:31 PM
Steve,
I had the decimal in the wrong place.
.1mm = 0.004"
and...
.2mm = 0.008"
Thanks for the catch.
Sherwood
Old 11-25-2007, 03:20 PM
1972_911T's Avatar
Hi Sherwood thanks for clarifying that for me, So basically you wouldnt re use any pistons that dont meet factory spec regardless of the wear limit?
1972 911t RS Styled
Old 11-25-2007, 03:23 PM
I would weigh the fact that the ring side clearance will increase with time and factor that into when I want to rebuild the engine again. Many manufacturers use the .1mm (0.004") as the service limit. As the clearance increases, the excess ring movement will cause the sealing edge to wear and thus increase blowby (compression loss).
Sherwood
Old 11-25-2007, 04:45 PM
Hello, Steve.
You will find most used Porsche forged pistons are scrap for this very reason I'm afraid.
ie top ring groove wear..
I would not use any piston with over 5 thou side clearance..the rings will break for sure when revved..
I'd say 8 thou is very big!
Good pistons are costly but cheaper!
Kind regards
Old 11-27-2007, 02:41 PM
