What Cam for 993?
Can't seem to find a lot of info on this, so what cams can I run in a basically stock 993 3.6 motor?
It's a '95 with '97 Vram intake and custom ship, to be remapped. TIA, John |
993 RS, or 993 super sport grinds.
Use the RS grind on any of these engines with a factory intake system; the Super Sport (Cup) profile does not idle below 1000 RPM.
Can you elaborate on the performance changes for the RS cam?
Thanks |
RS cams add about 8-10 HP to an otherwise stock 3.6 as long as the software is mapped to suit.
Installing the RS bigger intake valves adds more HP, as well. :) |
| All times are GMT -8. The time now is 07:06 PM. |
