3.0 EFI Cam Choice
Whats the best cam for use on a 3.0 engine with EFI. Engine will be 9.8:1 twin plugged and run on ITB's is 964 profile the best choice using the original CIS pistons?
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 |
for my bitz kit the 964 had a rough idle below 1100, hard to say if it was the CAM, however that was the big change I made during my rebuild. Well, that and higher compression.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
3 restos WIP = psycho
The sky should be the limit on ITBs with that CR. You have no need to mitigate reversion problems with that set up. I'd run Mod-S cams of Mod-Solex cams. Lots of fun.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
I would rather be driving
A 964 or Webcam 20/21 grind is about as aggressive as you can get with stock CIS pistons. You could have valve pockets cut in them, loose a few tenths of compression and then run whatever cam you want.
I am sure John Dougherty (camgrinder) might have another suggestion. give him a call or email since you are across the pond.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Good call, Jamie. Totally forgot to mention the piston relief cuts. Still shouldn't drop CR below 9.5:1. Still a very, very good CR.
Any cam with a narrow lobe center (lots of overlap) will cause reversion issues at low rpms. This means you might have problems getting a good MAP signal at idle. Are there ways around it? Sure. A few examples would be: increase idle speed, run alpha-n at low rpm and switch to SD off-idle, use a ballast tank for the MAP signal , and have custom cams made with a wider lobe center. The obvious answer would be to just keep your foot in it.
![]() I am currently using a ballast tank for the MAP signal and it really works to quite the noise. Think of it as sending the vacuum lines to a tank that mimics a common plenum. I am in the process of having cams made with John. I am getting a DC40 made on 108 lobe centers. This will broaden the torque curve and reduce the reversion issue. Similar tricks can be played on other cam grinds. BTW, with MS you w ill want a MAP_dot signal of less than 40 at idle. Mine was almost quadruple that until the ballast tank was installed.
A for MAP signal, I am using a custom made vacuum manifold that each throttle links to. My 3.4 has DC44's on the 108 lobe center and my load signal is rock steady, no pulses at all.....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Do you have any pictures of that?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
