Identifying MFI Pumps
There are multiple plates on an MFI pump, the one we all now that goes 0408 126 0## that identifies the pump number for Porsche Applications. What do the other plates identify, can you use these to ID a pump that doesn't have the Porcshe Number Plate?
For example on a 911 T Pump 0408 126 015 There are also plates lettered: EP/RLA 1/48R and PEDGKL 60/120 R3 V/X Any one have any other Pumps around and can post the numbers? |
http://forums.pelicanparts.com/porsche-911-technical-forum/367667-what-these-mfi-pumps.html?highlight=mercedes+mfi
That's not a "g" it's a six. . .PED6KL . . .probably Pumpe Einspritzung Doppel-Reihen 6 Kolben Lager or something like that. . . Double-row injection pump, six piston chamber is my guess. If you see a PES. . .it's single row, either a Benz pump or the fabled 906E. . . not exactly a junkyard item. |
| All times are GMT -8. The time now is 04:48 AM. |
