efhughes3's Avatar
She is soooo close.....I can almost feel her!
I got my intake assembly finished today, and back on. What a bunch of wires, plumbing, etc....makes you long for the old days. But, the good news is, I only had a 1/2 box of parts left over.
An admission of guilt: I only put the dizzy cap on and stuck the plug wires in the holes. Tomorrow, the plugs go in, and the wires are on for good. Then, the sheetmetal and the crank sensors, and the oil breather hoses and I'm pretty much done. The goal is to get the engine back in this weekend.
Rude awakening: Since I'll be twin plugging next year, can someone confirm that I'll need to put some holes on either corner of the front tin for the bottom plug wires? What size is common? I shoulda thought of this BEFORE powder coating.....
Lastly, I'm leaving a BIG carbon footprint today; bought 1 case of Brad Penn 30W break-in oil and two cases of their 20W-50 for the first two fills. $170 lighter in the wallet, not to mention 3 filters.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 12-04-2007, 02:49 PM
Looking good Ed, and good call on the Brad-Penn. I was finally able to get my rebuild fired up just last week. There was no other feeling than when she finally turned over.
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 12-04-2007, 04:44 PM
964 3.6l twin plug motor uses an oval hole and gasket on the 3 plug wires to go through the sheet metal. I will post some pics tomorrow, but the cross sections of the hole are 59x30mm.
1981 911sc RoW Coupe (forever under 3.6L conversion)
2003 996TT Basalt black
Old 12-04-2007, 06:27 PM
efhughes3's Avatar
Thanks, I'd appreciate the pics. After looking at this closer, I think that it makes sense to put the holes outboard of the chain cases, which would mean the holes would go in the side tins, not the rear piece I had in the pic above. In measuring the surface area available, it seems like a 1 1/2" or ~40mm hole saw may do the trick. Your oval measurements are in the ballpark.
Ed Hughes
2015 981 Cayman GTS
Old 12-04-2007, 06:35 PM
Yes it runs
tsiegwart's Avatar
Send a message via AIM to tsiegwart
The fuel rails and other hardware you had plated really turned out well. It looks fantastic.
Todd, Minneapolis
1987 Targa
TargaBlog http://tsiegwart.wordpress.com/
32C #4
Old 12-05-2007, 11:59 AM
I have individual holes in the sheet metal that flanks the valve covers, with grommets protecting the wires from the metal. See pics.
Old 12-05-2007, 01:04 PM
Here you go. The hole is toward the distributor end of the engine.
Sorry I have problem uploading photos directly to the forum from my dial-up connection.
http://i21.photobucket.com/albums/b295/NoEardGoat/P1010231.jpg
http://i21.photobucket.com/albums/b295/NoEardGoat/P1010232.jpg
JP911: Where did you get the bracket that holds the spark plug tubes against the engine? Those are slick. I would love to use them when I install my motor.
Old 12-05-2007, 08:24 PM
efhughes3's Avatar
Thanks for the pics.
I know Supertec sells the lower plug wire retainers, as do some other vendors.
Here's what I ended up doing today:
Ed Hughes
2015 981 Cayman GTS
Old 12-05-2007, 08:33 PM
