-   -   Race gas (http://forums.pelicanparts.com/911-engine-rebuilding-forum/380537-race-gas.html)
J P Stein 12-03-2007 08:15 AM
Race gas
My rebuild this winter includes some Mahle 10.4:1 pistons. The motor is single plug and I'm gonna need race gas. So, what octane. I'm looking at Sunoco 100 unleaded.....good enuff? Sunoco 104 which may be leaded?
Steve@Rennsport 12-03-2007 08:57 AM
Sunoco 100 is fine; Sunoco 104 is also good stuff,.....both are unleaded.
Twin-plug that thing!!!!!
It pays big dividends in torque & throttle response. :)
J P Stein 12-03-2007 10:57 AM
Who.... me the CSOB?
The thing is a black hole in a parking lot........
Between the rebuild & an LSD, I'm tapped out.
Britain Smith 12-03-2007 12:35 PM
Is the improvement in torque and throttle response a function of the twin plug or the higher compression?
-Britain
Steve@Rennsport 12-03-2007 04:28 PM
-Britain
Both!!!!!
Two flame fronts and almost half the necessary ignition advance make a more efficient engine.
Added compression makes more torque, too.
Aside from the initial $$$, there is nothing bad about it and given the cost of $7-8/gallon race fuel, its a good investment.
Britain Smith 12-03-2007 05:17 PM
For JP's motor, will the tuning for race gas be significantly different than pump gas give that we are running 10.4:1 and single plug.
-Britain
North Coast Cab 12-03-2007 05:50 PM
At least get the heads drilled for twin plugs, only a few hundred dollars. Then down the road you can add the ignition set-up to take advantage of it.
J P Stein 12-03-2007 05:59 PM
The long block is together and it ain't coming apart......well, unless it does self disassembly.:eek:
Hay, it's a low rent 914 AX car not one of them purdy 9elebens.:D
Steve@Rennsport 12-03-2007 08:21 PM
-Britain
Not appreciably,...........
camgrinder 12-05-2007 03:51 PM
What camshafts are you running? and in what size engine? What octane pump gas do you have up there?
I love the Sunoco 100 GT.
J P Stein 12-05-2007 07:00 PM
Solex cams. in a 2.7L. a very good Autocross cam, I've found. It's wide power band is just the ticket. Mahle P/Cs @ 10.4:1. Our pump premium is 93.
It's not as pretty as the good Mr. Cramer's. ....
http://forums.pelicanparts.com/uploa...1196909838.jpg
J P Stein 12-05-2007 07:08 PM
Another. One of the cams was NOS in the original package!
The other had been "touched up" by Web cams.
Note the plugged centeroiler passages. .....:Dhttp://forums.pelicanparts.com/uploa...1196910462.jpg
Steve@Rennsport 12-05-2007 11:14 PM
Lookin' good, Gents......... :)
