-   -   3.3 L Cylinders with Base O-rings (http://forums.pelicanparts.com/911-engine-rebuilding-forum/380548-3-3-l-cylinders-base-o-rings.html)
mbrown 12-03-2007 08:51 AM
I have the 3.3L turbo cylinders with the crankcase-to-cylinder base O-ring groove. When installing the o-ring, do I use the metal base gasket as well?
Regards
Mike
