3.3 L Cylinders with Base O-rings
I have the 3.3L turbo cylinders with the crankcase-to-cylinder base O-ring groove. When installing the o-ring, do I use the metal base gasket as well?
Regards Mike |
Yes, and spray the copper base gaskets with K&W copper coat (get it at NAPA)
G'day Brian...
Thank you very much...just what I needed to know. Regards Mike |
| All times are GMT -8. The time now is 02:08 AM. |
