-   -   Using a 993 Oil Filter Console on an Early Motor?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/381305-using-993-oil-filter-console-early-motor.html)
tom1394racing 12-07-2007 02:27 PM
Anyone tried this?
http://forums.pelicanparts.com/porsche-911-technical-forum/296088-about-installing-993-oil-filter-console.html#post3632073
aturboman 12-07-2007 03:25 PM
I did just that on my 930 motor build, used all new factory parts and deleted the engine cooler. You need a conversion pipe to connect up the oil tank but it is bolt on from there.
Advantages are second filter in the system, less weight out back, and the number 6 cylinder (if memory serves correct) runs cooler.
