-   -   Help after rebuild, please - brake pedal stiff but weak breaks (http://forums.pelicanparts.com/911-engine-rebuilding-forum/381605-help-after-rebuild-please-brake-pedal-stiff-but-weak-breaks.html)
sms1305 12-09-2007 04:13 PM
I didn't do any break work during the build, but now the pedal is hard but the breaks are weak. It feels like there is no power assist. I replaced the clutch slave, though. Can it be related? Thanks.
tctnd 12-09-2007 04:37 PM
Are you sure you are getting vacuum to the booster? You might have left the line plugged or disconnected.
regards,
Phil
sms1305 12-09-2007 07:32 PM
Thanks, Phil. You jogged my memory that I had to disconnect the ABS pump connector as part of the prep for engine removal - though I don't know why. Forgot to reconnect. Much better, now! Dumb...
sww914 12-09-2007 07:47 PM
Not dumb, just normal.
efhughes3 12-11-2007 07:09 PM
I think the engine build is the easy part. It is getting all of the fuel injection, electrical and misc junk at the end all done to get the engine started. I forgot a couple of things too. I think with me, it was being anxious to get it in and running.
