By George, I think I've got it....
I did the 9V battery on my dead injectors today and a little bit of tapping on them. Got good clicking, so I hooked them back up and she fired right up. A bit rough below 1K RPM, butv smooth above. It was friggin' cold today here, so I'm guessing that played into it. But, I think I have 6 cylinders running.
Still no oil leaks, so I think I'm out of the woods on that worry! I've got to put the muffler back on, and hook up the O2, then she's hitting the road for a short drive tomorrow!;) |
Excellent, good to hear Ed!!
Cheers |
Excellent!
Thanks guys!! I still may have a sticky injector in #5, but it seems to be intermittent. Maybe with a drive, they'll all loosen up a bit. That could be why it was rough under 1K, but it's only 39 degrees here today on a brand new engine, so I guess I can't expect it to purr?
I think the girl needs to see 5K tomorrow! I crawled around underneath, and I may have a drip from the LH top valve cover, I'll check the nuts on all of them once last time. But, it runs, no CLANGING that I can hear over straight headers, and I'm pretty pumped!!1 |
Great Job Ed!! Its such an awsome feeling when it finally fires up. I couldnt beleive it when it happend though!
Way to go Ed! Aren't you moving out this way soon?
Woo Woo - congrats ed - way to go!
Ed,
Drive it like you rebuilt it! JC |
I got my shifter linkage hooked up and my muffler on today. But, it is raining....s'posed to rain tomorrow too. :(
Thursday should be clear, so she may have to wait until then. But, she's ready to rumble. http://forums.pelicanparts.com/uploa...1197406495.jpg http://forums.pelicanparts.com/uploa...1197406553.jpg http://forums.pelicanparts.com/uploa...1197406731.jpg |
Man, I can't wait. I've followed all your threads.
Sorry about the rain. It's 5F bleepin degrees where I'm at, but it should get to 50F by April. Good Luck |
Ed,
Congrarulations, looks great. This weather must be killing you. Enjoy the first drive. Regards, Bob |
The weather should clear in a few days. It is nice and sixty-ish degrees down here in Hell Rio.
Did you get the injectors rebuilt? |
MPSC? Michelin Pilot Sport C....
And by the way Ed, congrats on getting the engine fired up and ready for break-in. What's your plan for twin plugs? |
Cups
The fact that it's in the 30's here today also figures into it. |
Did you pull the injectors to check them? When I had problems I removed them, filled my old pressure brake bleeder up with fuel, hooked it up to the injector and touched it off with a 6v battery. Now I know this is living dangerously but it did work, and makes a heck of a flame thrower.
| All times are GMT -8. The time now is 04:56 PM. |
