10.5:1 Pistons and EFI
I'd like to use the 98 mm JE 10.5:1 High dome pistons on a 3.0L with the 3.2Carrera Intake. I also have a Webcam 120/104. I plan to use ported 3.0L twin plug heads.
This piston / cam combo is promoted as a carb or MFI combination however I wonder how it would work with the 3.2 Carrera intake. My purpose is to build a higher hp Fuel injected motor based on the 3.0L case. Anyone have some experience with this combo? |
This thread may interest you. I am consider a piston change as well...
http://forums.pelicanparts.com/911-engine-rebuilding-forum/381867-intake-suggestions-3-0-electromotive-fi.html |
Excellent thread and sub threads - thanks!
What I'm trying to understand is more about the relationship between the intake, piston domes and cam timing. |
I did exactly what you did with DR20 cams and got ~235HP and a flat torque curve with power to 6800rpm.
You are going to have some trouble using that intake with those aggressive cams. :)
Common-plenum intake manifolds do NOT like cams that have much duration or overlap as that causes a lot of reversion that makes for very poor idle and drivability below 3K-4K. If you like those cams (I do), you should use an ITB system of some kind. |
I would like to point out that JE has come out with a whole new line of Porsche specific forgings to address the issues some have had with them over the last decade, which I am told, is basically now just like a piston from CP. They were introduced this year at PRI & SEMA.
Hi Charles:
LOL,..Only time (and a lot of race miles) will tell if they are any more durable than their previous offerings. :) :) |
And you'll hear it here first, on the Pelican Engine Rebuild Forum!
(shameless plug) |
I still swear part of the problem is probably as a result of the expansion of the 2618 forging outpacing the Mahle cylinder and possibly too how the pistons are cammed. The few cases of wripped-out wrist pin bosses sure look like the piston siezed in the bore or was in the process of doing so, but you know as well as I do, that it's hard to make heads or tales of anything once that happens. Knock on wood, I have yet to date have a single JE come apart in a Nickies cylinder, and i'd be willing to bet if I tally it up there are somewhere well over 1000+ sets in circulation with a JE piston in them.
Flatspin,
tried responding to your mail but got rejected returns...here's the info you asked for... Hi, I used 10.5:1 JE pistons (which cc'd out to 11.2:1!!!) Twin plugs Alu 3.2 intake Have used both Adaptronic and Megasquirt ECUs. DC20 cams K&N intake for a cummins 7.4l diesel Twin triple-channel Haltech ignitors Twin Ford EDIS-6 coilpacks SC fuel pump (4 sale, replacing with higher-output series pumps for supercharged setup) 26lb accell injectors (for sale, I am replacing with 55lb for the supercharged setup) Edelbrock rising-rate FPR Flowmaster 80 2-in2-out Bursch headers Anything else I can help with? |
Thanks JohnJL
I'm not familiar with DC20 cams? Are they similar to 964? SC? Webcam 20/21? What are the specs of this cam? I'd like to use MSII - I see you used this and switched to Adaptronic? What is you experience with the MS? |
They are similar to the 20/21. If you use a 12/104 you need carbs or ITB's.
Cheers |
I had trouble getting the ignition signal correct on the MS2. I am sure it is operator error. I switched to Adaptronic because the designer and manufacturer lives 10 minutes away and even with his installation and tuning support it cost 15% of what Motec would have cost.
I am running 98mm with twin plugged carrera heads, intake, and throttle body. The carrera head is a better match for the intake due to the orientation of the injector. Porting out the 3.0 heads doesn't leave a lot of room on one side of the intake port for the manifold to mate to. You will need ITB's for any cam with greater overlap. I am very happy with my 964 setup. 230RWHP on the first attempt at wot tunning on the dyno. Max torque is a little high at 5000RPM but is very flat to redline.
FWIW after two seasons with this combination, one of which running too lean a fuel mixture due to a calibration issue (14.2 avg) mine are holding up well (JE with Nickies). I was suprised at how little piston skirt abrasion I saw on this setup compared to the JE/Mahle combo's I've seen... |
Are you using the 3.2 Carrera intake or the 964 Carrera intake? 3.2 Carrera Heads? The 98mm Pistons/cylinders: Mahle 10.1:1 CIS dome style or JE 10.5:1 high dome? What cylinders did you used - Mahle? Nickies? Carrera bored and replated? |
I love the 120/104 cams. I have them in a 3.4 (98mm Mahle 9.7:1) with PMO 50mm carbs (still working on off idle transition). The low rpm power is not all that great, but not bad either - above 4500 rpm it is a great deal of fun. A light 2400 lb 1970 shell makes for 12.5 second 1/4 mile times @ 118 mph. 60 foot time was poor as you can imagine.
Have fun. |
thanks, -Chris |
CP Pistons is a member of the Pankyl Group - Pankyl makes Porsche's Ti rods :-)
http://cppistons.com/ |
| All times are GMT -8. The time now is 12:33 PM. |
