-   -   Hydraulic Chain Tensioner upgrade (http://forums.pelicanparts.com/911-engine-rebuilding-forum/382229-hydraulic-chain-tensioner-upgrade.html)
atrox007 12-13-2007 06:17 AM
How can I tell if the Hydraulic chain tensioner upgrade has been completed?
Do I need to take off the cover to the chain tensioner area or is the new cover plate different enough to tell that the upgrade has been completed?
I have just purchased a 81 SC Targa.
gigem75 12-13-2007 08:14 AM
I believe you will see a "T" in the oil lines to each head about half way between the block and the head. There should be a metal tube off the "T" that goes to the chain cover and is secured with a banjo bolt on the front of the chain cover/
shbop 12-13-2007 09:38 AM
http://forums.pelicanparts.com/uploa...1197567309.jpg
First of all. Thanks to Dave, it's his photo.
If you look carefully at the timing covers, you'll see a small oil line droping down and going into the cover. Without the upgrade this (tee) in the oil line wouldn't be there. Hope this helps.
isby 06-10-2020 04:58 AM
Thank for this photo - very helpful. Looks like the tensioner upgrade kit is readily available. Any thoughts out there in terms of whether the upgrade is a project for a handy weekend warrior or should it be handled professionally. I know what's coming -- how handy?? Thanks all.
nene 06-10-2020 07:39 AM
It is not difficult and you can do it, just do a search here.
Serge
nene 06-10-2020 07:42 AM
Here is the link to the site within Pelican....https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/16-Carrera_Chain_Tensioner_Install/16-Carrera_Chain_Tensioner_Install.htm
