-   -   Dual pipe exhaust for 2.4S? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/383784-dual-pipe-exhaust-2-4s.html)
elflamo 12-23-2007 01:07 PM
Hi all,
in the Porsche 911 Performance Handbook (Bruce Anderson) it is mentioned that the power of a 2.4S can be lifted to 210 BHP when using a dual pipe sports exhaust.
- which exhaust is this? I have bought an exhaust with outlets both left and right, but I am wondering if the book actually refers to the exhaust with the two parallel pipes exiting in the middle of the exhaust (is this the 'pea shooter'?)
- Has anybody tried this?
Thanks!
Dennis
Eagledriver 12-23-2007 01:38 PM
I don't think that number you quote is in the book. His book does show that you can gain about 10 HP with a sport muffler. The dual outlet sport muffler is usually considered to be the "pea shooter" that you reference above. I believe that most dual outlet mufflers will give you this boost.
-Andy
Henry Schmidt 12-24-2007 06:42 AM
This one is from M&K
http://forums.pelicanparts.com/uploa...1198507317.jpg
210bhp 12-27-2007 09:55 AM
Is it true this type of exhaust works better with carbs than MFI?
Regards
Mike
elflamo 12-30-2007 09:05 AM
Andy, check the graph on page 141. Pretty close to 210
Dennis
Eagledriver 12-30-2007 10:37 AM
Dennis,
I have the older version of the book so my graph is on page 133. It shows a 10 HP increase at 5500 RPM. The stock curve stops there in the graph at 190 HP. Since the peak HP of the 2.4s motor is around 6200 RPM, this graph shows a stock 2.4 with about 200 HP. The improvement with the muffler is 10HP.
-Andy
