Where to buy Speedi-Sleeve?
Our host doesn't carry these, anyone have a source (and possibly the model used for the 964 rear main seal surface...)?
http://www.chicago-rawhide.com.au/Products/speedisleeve.htm |
I have used these types of repair sleeves before. It was not for a Porsche. The results great, it quickly took care of the leaking front oil seal and harmonic damper on a few vehicles over the years. After installing the sleeves, ZERO leaks. Still no leaks, and it has been 6+yrs no on the last one I did. I believe that I purchased them either from NAPA, or CARQUEST. Good luck!!
Stoddard list's them for some models I hope that helps
thanks! I send Stoddards a message - they don't seem to stock the 964 flywheel end sizing. |
Hi everyone, I have been using these types of shaft end repair kits for many years. I have never had a problem with any of them, regardless of the manufacturer. I really liked the link that was posted, gave a better insight on the item. CBRacerX, if you send me the specs, I can check here locally for one. I have always been able to get whatever I needed, even if they had to order it, I got it the following day. Let me know and I will check for you. Good luck, Tony.
Chris, The speedi sleeve p/n SIC-102-993-51 will fit all 9 bolt crankshafts 1978 to 1998. They are $41.50 and are in stock. Regards, Mike Garriga 911 Parts Specialist Stoddard Parts mgarriga@************* 1-800-342-1414 ext 3071 |
Great to know.
The speedi sleeve p/n SIC-102-993-51 will fit all 9 bolt crankshafts 1978 to 1998. They are $41.50 and are in stock. |
| All times are GMT -8. The time now is 02:30 PM. |
