Is 350cc per cylinder the most efficient size?
Somebody at another forum has quoted that 350cc per cylinder is the most efficient:
Do you agree? |
No, like most absolute statements, that is not true.
First of all, there is no definition of "efficient", but the writer seems to equate it to output. If so, his own example of F1 proves this false. The 12 cylinder, 3 liter F1 engines (250 cc) had a higher output than the 8 cylinder (375 cc) engines, which are closer to his ideal. The F1 organizers know this and have limited output by limiting the number of cylinders. Racing engine ideals are usually the result of an artifical limitation, like displacement. There is an SAE paper on this subject, it shows an increasing output (hp/l) for multicylinder engines as cylinder size drops from 400 cc to below 50 cc. An extreme example would be the 5 cylinder 125 cc Honda. Eventually, friction losses offset the additional output from the smaller cylinders. Of course, this has nothing to do with the selection of engine size for a 4 passenger road car which spends 85% of its life below 30% load. Ask someone who understands the actual conditions for the application, and the consensus ideal is a low reving 5 liter V-8, with 35% EGR and selectable cylinders. |
The writer's meaning of 'efficient' was power per unit displacement.
blue72s wrote,
No. In the 3.5L era ('89 to '96), there were no rules limiting the number of cylinders blue72s, Check your history, 3.5 liters, 12 cylinder maximum. The 10 cylinder engine had nothing to do with a fantasy about 350cc. I had to do with the new regulations moving the pedals behind the front axle line and a desire by Honda and Renault to demonstrate that they finally had enough computer power to go beyond the traditional 60, 90, 120, V angles. After two years, Honda switched to a V-12 with 291 cc cylinders and a 100 more hp. That SAE paper is 690748. 700122 and 640664 also show similar results. |
Oh, Steve McQueen sold one of his two Porsches ('69S and '70S) in 1970. Do you know which one it was ...? ;) |
He kept the better one ?
Have you read this ? : http://www.mcqueenonline.com/sportsillustrated66.htm Comparing different mfg's F1 engines is muddy, but Honda clearly made the engine with the smaller cylinders make more power, and they are numero uno, or duo. |
2.0S 170 hp 9.8:1 to
2.2S 180hp 9.8:1 10% increase in displacement but only 5.9% increase in hp 2.4S 190 hp 8.5:1 to 2.7RS 210hp 8.5:1 12.5% increase in displacement but 10% increase in hp 2.7RS to 3.2 Carrera 231hp 18.5% increase in displacement but only 10% increase in hp 3.2 carrera 231hp to 3.6 non-varioram 247hp 12.5% increase in displacement but only 6.9% increase in hp 2.0S to 3.6 non-varioram 80% increase in displacement but only 45% increase in hp |
blue72s; there's a lot of other things going on besides just the change in capacity. If you do a search back a few years on my signature, you'll see a bunch of data that I posted that compared the BMEP's of the different 911 engines. In a nutshell...
- CR's changed - The 2.2's through 2.7's all used the same valve size and porting (specifically from the S through RS), even though the capacity increased. This will significantly change the shape of the torque curve. - Induction systems (and as a result the cams) changed - Piston design changed as a a result of the induction system changes - The stroke (and the resulting dwell time near TDC) changed In a sentence, the engines were designed to develop wider torque curves using fewer revs in order to reduce noise and improve drivability. As a result the HP per liter went down (until the advent of the variable induction paths and variable valve timing), even though the torque/liter stayed the same in the face of increasing regulations regarding noise and pollution. |
| All times are GMT -8. The time now is 02:58 PM. |
