-   -   Need Confirmation on Ring End Gaps (http://forums.pelicanparts.com/911-engine-rebuilding-forum/384625-need-confirmation-ring-end-gaps.html)
vntgspd 12-29-2007 04:59 PM
I am in the process of installing new JE 85mm (84.92 actual) pistons with JE Proseal rings into my cylinders that were bored to 85mm. In checking the ring end gap I am finding that the first ring is tight at .12-.15mm and the second ring is tighter at .10mm. All measurements taken at room temp.
My Porsche Technical Spec booklet indicates .15-.45mm and the JE paperwork (vaguely) states .15 up to .17mm.
I am thinking they are made this way to facilitate filing for a precise fit in each cylinder so I am prepared to do this. But, before I start this process, I'd like a little backup from the experts regarding the need to file the rings and what the target end gap should be for each ring.
Thanks!
Mo_Gearhead 12-30-2007 05:58 AM
Go with the piston ring (J.E.'s) mfg.'s suggestion.
Most aftermarket/custom rings ARE tight/oversize and are meant to be filed to have a custom fit.
You will be comfortable afterwords, knowing they are all in proper spec.
