need measurement from engine case
Hi All, anyone out there have a '72 - '89 engine case sitting around?
I need to know the ID (inner diameter) of the hole in which the engine thermostat installs. I need this in order to modify the oil counsel on my 72 to take an engine thermo for an external oil cooler. TIA! |
The OD of the engine oil T-stat is 45mm.
Hope that helps |
| All times are GMT -8. The time now is 10:48 PM. |
