azporsche911.com
Hoffmanmotors's Avatar
Quick 3.0 top end question
Im getting ready to take the top end apart to replace the 1 broken head stud and all the lower head studs. My question is can the cam housing and heads come off as a unit or do i have to take it all apart? everything is clean and no need for attention as far as i know the car has 90K.
TIA
-Jeff
Jeff Hoffman (Son)
Tom Hoffman (Father)
79 911sc ROW guards red coupe
father son project.
Old 01-15-2008, 07:45 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
You can take the heads/cam towers off as a unit
Scott Kinder
kindersport @ gmail.com
Old 01-16-2008, 02:58 AM
abit off center
cgarr's Avatar
And thats the preferred way
______________________
Craig
G2Performance
Old 01-16-2008, 05:59 AM
azporsche911.com
I can also leave the cam and rockers in also correct. I have Wayne's book but it explains how to take it all apart during tear down.
I'm assuming i just back the rocker screws out as far as they can go so i have clearance for the valves not to touch the piston, remove chain boxes, then the heads/cam housing. Sound good? Sorry if i sound Newbish, Its because i am.....
Jeff Hoffman (Son)
father son project.
Old 01-16-2008, 07:54 AM
abit off center
cgarr's Avatar
You will have to pull the chain boxes if you leave the cam in. I think you can leave the boxes if you pull the cam? but since your doing lower studs just get them out of the way.
Craig
G2Performance
Old 01-16-2008, 08:01 AM
azporsche911.com
Thanks!
Jeff Hoffman (Son)
father son project.
Old 01-16-2008, 08:23 AM
It's a little tricky getting the cam ends around the chains but you can leave the cams and rockers in. Take notes on which way the chain slippers go and how to install in the right way so you don't trap the chain and have to remove the slipper again. I'd buy a couple of new slippers because the clips tend to break on the old ones.
-Andy
Old 01-16-2008, 06:39 PM
