-   -   Thoughts on 911/20 ST Type Engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/387301-thoughts-911-20-st-type-engine.html)
bumble 04-22-2010 08:50 PM
Hi Cameron,
That's a nice looking power curve...
What carburetor settings did you end up with (ie venturis, emulsions, mains, idles, airs etc, etc).
What intake/exhaust port sizes are you running?
Cheers,
Steve@Rennsport 04-23-2010 12:59 AM
Cheers,
Hi,
If I may say so, sizes are no reflection of head flow & velocity,........ :) :)
I've seen big ports that didn't move much air and I've seen smaller ones do very well, depending on camshaft profiles.
Certainly JMHO,
cameron.arnott 04-23-2010 04:24 AM
Mark
What Steve said on the ports :D As I understand its more about shape than size. That said they look freakin' huge and I think were roughly 38mm but they are not round.
Webers I think have 34mm main venturis, 140 main jets, 160 air jets, 60 idles, F3 emulsions, PMO tall manifolds - port matched.
As noted above there has not been enough time to play with the Webers to get a completely satisfactory result - out of interest my mechanic said it ran better with the standard secondary venturis than the talls which runs contrary to conventional wisdom. That may change with a change in emulsion tubes? Jetting is pretty good otherwise.
Cheers
Cam
