-   -   indicator range (http://forums.pelicanparts.com/911-engine-rebuilding-forum/389436-indicator-range.html)
tcramer 01-26-2008 02:27 PM
indicator range
Hi, what range dial indicator should I use for setting valve timing?Thanks,T.C.
Mo_Gearhead 01-27-2008 06:25 AM
Let's assume a camshaft had a lift of 12.7 mm (1/2 inch), you should use a indicator with at least twice that amount 25.4 mm (1 inch).
About ANY one (dial indicator) I have ever seen will have that much travel (and more).
ChrisBennet 01-27-2008 08:33 AM
I've never timed anything but CIS and Motronic cams and a 1/2" dial indicator works fine for those motors.
Look at the setting distance for your particular cam and you'll know what size indicator you need. On a 3.0/3.2/3.6 it's much less than 2mm.
-Chris
safe 01-27-2008 12:52 PM
Why would you need one with twice the amount of lift possible?
degreeoff1 01-27-2008 02:29 PM
yep Waynes book says you need more than the timing specs (in my case it was .02" (less actaully) AKA 4.5 mm
Walt Fricke 01-30-2008 10:25 PM
Well, you really don't need much more lift than the timing spec. You aren't measuring max valve lift, just lift at overlap, and that's not much at all no matter what cam you use. It doesn't matter if the indicator tip quits descending because it has reached that end of its travel.
What is more important is that the tip is long enough, because the fixture holds the indicator a fair way up from the valve retainer and you need reach. But you can buy an extender as long as your indicator has a removeable tip.
Walt Fricke
