1989 964 C4 Engine re-build
Today while driving to work, I was in third gear at about 6000 rpm when I tried to shift to 4th gear and wound up back in second...:( My car lost power wound on the side of the road and would not start, Although she cracked very strongly. I had my car towed home. I was told by a few different shops that the rocker arms are probably snaped and the valve may be bent. I have been given price ranges to get the car back to OEM stock format in the range of about 5 - 6.5k. I understand that is a complete top engine re-build.
My question, once you have the engine out what are the good upgrades to have done at that point? Should I just have 3.8 jugs put on? New Race cam, Port and polish the heads? I'm not really sure what the cost are on such upgrades and what the profomance increases I could expect from such upgrades. Anyone have any thoughts on what my best rout would be? I live on Long Island New York anyone have any experience with an race engine builders out in these parts? I'm open to your suggestions and comments. Thanks for your time, Sheldon |
Sorry to hear about your troubles. I have an early '89 C4, too.
I recently put late style 3.6L P/Cs in and had my heads cut to accomodate gaskets. I like the C-2 sport grind, but probably wouldn't do it again for a daily driver. I would definitely upgrade the rod bolts, but not sure I would use ARP for my head studs again. There is a lot of authority here that suggests the 993 head studs are more than sufficient. It's not clear whether you over-reved or not, but I might be thinking about doing the bottom end, too. Good luck! |
Ouch! Really sorry to hear that.
I did the same thing at a track; it broke rockers, bent all the exh valves, etc. Bill Rudtner is right in your back yard. Dangerous man. Give him a ring. Rudtner's European Auto Inc / Rudtners Racing 16 Saint Johns Place Freeport, NY 516-378-8769 Good luck! Glenn |
Glenn,
Bill Rudtner is Dangerous meaning good or Bad? I have some good things about him as well as, a few not so good. Can give me any experience you have had with Bill? Would it be worth while to upgrade to a 3.8 jugs? |
Sheldon,
I'm sorry. My sense of humor often doesn't translate. I meant good. Dangerous, as in he holds the keys to candy-land (more HP, modifications, upgrades, and all that is sinfully fun). He knows his stuff, and has been a good source of diagnostic help and suggestions for me, and many others on the board here. I've not had him do rebuilds, but others here have, and have splurged for some serious upgrades (3.8 and 3.9 liter stuff). He just modified some crankshaft bearings for me. I'm sure you'll find all shops have pros and cons. Just give him a ring and talk through your goals. If you really want someone to just do the top end, keep it stock, and do it the most cost efficient way, I have someone in CT I'd recommend. |
Glenn,
Got it Thanks...I am torn between getting aggressive with the rebuild or putting it back to stock. I guess its the cost factor. 6k for a top end rebuild verus 10-15k for a 3.8 with all of the bells and whistles. The questions is ...IS it worth the upgrade? and money? Sheldon |
IF your P/C set are in spec, you can send the cylinders to Steve at Rennsport Systems and he can have them moddified to accept the 993 sealing ring for a very reasoable fee. He has done a set for me a couple of years ago that worked perfect.
I have only heard good things about Rudtners and Bill and Tim both post on these forums a fair bit. They helped me a lot with the EFI set up on my 3.4 and I am yet to spend a dime with them. They were superb. Cheers |
Jeff,
Thanks - I did speak with Bill today. He seems to know his stuff and he is not pushy at all. I have spoke with a few big name shop here locally and a lot of them want to know my budget. To which I respond what does it cost to do a full rebuild? and than I add the upgrades on to the discussion to see their ideas...WOW how the opinions differ. Some what to do turbos others say do 3.8. The list is endless, I am trying to just make sense of it all. I want a complete rebuild and I do want some upgrades. I'm just trying to figure if an upgrade to a 3.8 would be the way to go and at what cost? |
There are times when a missed shift doesn't mean a rebuild. Porsche put the cast rockers in most of these engines so that they might break rather than bend the valves. You can do a leakdown test and it will tell you if the valves are bent. If they aren't, you can just replace the broken rockers and go.
One of my customers let his buddy (with $$$) share his car last year 3 times. 3 trips to the track, 3 missed shifts. Once, it broke 2 rockers, I drove up to Laguna, did a leakdown, replaced 2 broken rockers and they finished the weekend. The next time- missed shift, 4 broken rockers, bad leakdown. It spun one of the cam nuts loose, cleaned the teeth off of the camshaft sprocket mounting flange, ruined the cam sprocket, bent 5 exhaust valves, broke the guide boss on one head, destroyed one camshaft lubrication tube, and I think that's pretty much it. The next time it only bent the exhaust valves and broke 3 rockers, but I was finally able to talk him into racing valve springs with titanium retainers that he hadn't wanted to spend on previously. Only one missed shift since then, no damage. I don't know what kind of rockers 964's have, it may be that none of this applies, but I really like to hear myself type. |
Sorry to hear about your event. I think your connecting rod bolts are stressed beyond usage if you over-reved the engine. 964 are known for con-rod bolts to be a weak link.
This is why raising the rev limit is one way to eventually stress them to the point where they let go. Damage to them is accumulative since they keep stretching. Eventually, one becomes loose and you have a catastrophic failure. So I would definitely consider changing and/or upgrading to ARP bolts while the engine is out. They can be changed without splitting the case once the head and cylinders/pistons are off. However, the best way is to use a stretch gauge when installing the ARP bolts. When I rebuilt my 3.6 I opted for not splitting the case and had the ARP bolts installed with the torque method one at a time. Nothing wrong with that in itself. However, even though this is unrelated now I am paying the price with a leaking #8 nose bearing. Arrrgh - I wish I would have gone all the way and done the full rebuilt.... Ingo |
Our benevolent benefactor Wayne describes a leakdown test here- http://www.pelicanparts.com/techarticles/mult_Engine_Rebuild/mult_engine_rebuild-2.htm
You need a tool to remove the spark plugs, a leakdown tester, a tool to remove the distributor cap, a tool to turn the engine over, and the ability to find TDC on each cylinder. To lock the engine in place, you can just put it in gear and apply the parking brake each time you reach TDC. I bought a $40.00 leakdown tester at Harbor freight once, I took it back and bought a better one from a tool truck. |
Thanks for the info. Do you know if there are services that come to you to do the leakdown test?
Thanks, |
I don't think so. If you were about 3000 miles closer to me I'd stop by and help you.
LOL thanks for the offer :)
Someone mentioned it could be just the distributor cap - any thoughts? |
I spoke with a local Porsche shop. They suggested that the distributor may have been broken when I over-reved the car. The reason being is that the car doesn't run and my undertsanding is that even if values are bent or rocker are broken the car would still run. just not very well. Does that make any sense, why thoguthts and suggestion please.
Thanks, |
Very easy to pull the distributor and see if it is broken. Two nuts. You can mark its position for future reference. You can also remove your cam covers and see what the rockers look like.
Aurel |
Hey guys why not do a simple compression test? If the rockers are snapped then there will be no compression. The tool is only 20 dollars and it only takes a little over an hour to do yourself. If you do find a piston with no compression then that is where the search begins. I have had a few different vehicles leave me dead on the side of the highway :mad:and most of them have been electrical related, however none of them were combined with a missed shift. Dont be afrtaid to tear into it yourself, one way to look at the problem is that at this point it would really be hard to make the problem any worse.
Great Point ...if it is just rockers that is pretty easy to fix...Meaning cheap...$$$ otherwise it will be more costly doing an entire top end rebuild...
Thanks for everyone input and advice. I have taken the to a local shop, Rudtner's European Auto Inc - Rudtners Racing aka Wild Bill Rudtner. So after reviewing my options I decided to purchase a 1993 RSA motor with 40k on it. Wild Bill has agreed to install it and hopefully I will back on the streets very soon. When this car is finished I will probably sell this car and try and find a C2 to create a monster or maybe finds someone old project car have some fun. will see...Thanks again for all of the advice.
Sheldon |
Sgoldberg- I havent seen one cheap, but would you consider mabye upgrading to a 3.6 V-Ram motor from a 993 if a whole rebuild is warrented? I know it would be money, but I had the same kind of car you have with the 3.8 and was not very impressed- I believe that you could get more out of just swapping a 3.6 v-ram in there. Now some of the benefits include, better heads, cams, hot wire mass air, variable intake plenum, hydro rockers(no more valve adjustment), etc...
If I could do it all over again with an n/a motor I would have gone this route. Or you could go get a 930 motor and swap it in... |
930GT-40r - Interesting points - the more people you speak with the conflicting opinions you get. i was told by a few folks that the Hydo valves are not better. So i could have purchased a 993 engine non v-ram, But I didn't because of the issues with hydro valves and rockers.
Hopefully this car will run good and i'll be back on the road ASAP. Any experience with leak down tests on a cold engine that has been store for 8 -10 months? Do the leak downs get better or worse with a warm engine that has not been still for a long time? |
Well I have been down your road before, and from experience I would go with a 993 v-ram before I went with a 3.8 conversion. As for the hydralic lifters, I have never seen a 993 with rocker issues in the 10 years Ive worked with them nor the 3 years at porsche of Fairfield. I think rocker issues that your hearing of is somthing more to the tune of a 5-2nd downshift or neglect. I wouldnt steer you wrong, the 993 is a better motor- Did I mention that I seen a 993 with 245,000 miles on the orig. motor? This thing never even threw a secondary air code (somthing you wouldnt have to worry about because your car is OBD1) which is the only real problem with those motors. Pm me if you want any more info, I could go on forever about this.
pm sent
Replied
SHE runs again...I paid a little over 5400.00 to have a 40,000 mile 1993 RSA motor installed into my 1989 C4. Is that expensive ? Am I crazy to feel I over paid for a service? That price doesn't included the motor. That is just for installation NOT THE MOTOR!
5225.00 for the 1993 RSA 40,000 miles 5470 for installation of a motor. Is that excessive? I feel the motor is a good valve she runs strong! |
I screem like school girl!!
that sux. But thats awsome that you got your baby back |
Yeah I happy to have the car back she runs great ...But I'm more that a little upset. Just because you can afford cuban cigars doesn't mean you should be charged for Cuban cigars when you are buying regular cigarettes. I knew I had to pay otherwise my car would be held hostage!
I guess you live and you learn. The kicker is that guy tells me he could have charged me anothe r10 hours of labor...LOL |
Tell him to kiss my @$$, not yours but mine.
That was a 1,500-2,000 job to a good repeat customer even after the cam switch and what have you. If it was a direct bolt in with no crap, I would charge $1,000 to someone who I didnt know. |
I agree the motor was a "direct bolt in" if you build race engines this should be a simple job not a 70 or 80 hour job. But I guess some folks would rather rob you today ...ONCE - instead of have you business for 10 or 20 years. Makes no sense. I would understand if 5 out 10 people would say this is a big job! Not one of the poeple I asked said this was a Major overhaul . Most people think that price should have included a complete rebuild! you would think Dr Porsche himself did this job...WOW. Can't get over it! Now the guy is trying to talk me into a turbo system that job could cost me my house and left kidney and the system would be used at best! sorry for my rant!
I feel like i went thorugh my own personal ENRON scandle! |
That was a D-bag move for your guy to do- He made you grab your ankles in a time of need. |
You should also post the fact the the engine supplied from you was from an RS engine that does not have the provision for power steering as your C-4 engine does and needs. That we had to switch the cams over as well as the intake, adjust the valvesand swap the cruise control unit, the labor charge also included diagnosis of the first engine with performing leak down tests on both your engines, and reassembling the original engine after the cam swap, remounting it on the supplied pallete and loading it on a truck. We got paid for total time spent and every thing was discussed with you during multiple before and during the job.
You seemed thrilled when you picked up the car. Next time make sure you get the whole story out. Bill Rudtner |
before I'm done here don't forget the incompatible wiring harness that also had to be changed to make the C-4 trans work properly and all the rusted bolts and rotten engine tin that took time to be heated and or cut on your very abused C-4. I'm sure the local corner service station could have done the job just as well and for a lot less.
FACT- I AM THRILLED THE CAR IS RUNNING just the same as I'd be thrilled if I owned the NY Yankees, but that doesn't mean I would want to pay 8 billion dollars to own the Yankees! - I’m not saying the job was done incompetently. Conversely, I believe the job is excellent. I just feel like 5400 is a bit excessive to swap an engine. If you consider the engine cost $5225 and the engine swap $5400. I could have rebuilt the engine for that combine cost! Of course your rebuild would have cost me closer to 15k. I went into this job with the false expectations of $1520 – $2280 labor.
Again, I am not saying the job was bad the engine runs great. I feel a paid above premium to swap an engine! Now we can argue the points of “well the engine needed a lot of work to swap” or “maybe you didn’t fully understand the amount of work to swap two similar engines” thusly setting my expectations low. Before decided to go with you I called every Porsche shop on long island the average price was 1100 to swap an engine. You are more that 5x the amount. I went with you because you’re the best. I am not saying I wouldn’t use your services again I just saying before I did I would want a full exact estimate before I started work. At times it seemed as if I was asking for winning lotto numbers when I asked for a for a price to do work. Not sure what is right, but I know 5400 is ridiculous considering you’re an expert in building Porsche motors and this should be a basic job. The Porsche dealer in Freeport judges the engine swap at 13 hours labor with cam changes. Wire harness change is 1 ½ hours labor. SO in your opinion the Porsche dealer down the block from you is a local corner garage? 14 ½ hour labor at 126.00 per hour is 1827.00 added another 1000 for issues and unforeseen items 2827.00. Not sure why your outraed I'm the one that raped! |
I'll give you a call later today we can discuss...I have your cell number
I apoligize for my statements GTU- I am not going to comment on this any longer.
I have been running this motor for the past few days SHE RUNS GREAT! No knocks shakes or pings....No smoke or oil leaks she runs perfectly!
| All times are GMT -8. The time now is 12:57 AM. |
