2.0L Came Alive Today
Engine sounds great! Drove around the neighborhood, rev'd to 8000 quicklyhttp://forums.pelicanparts.com/uploa...1201651713.jpg
http://forums.pelicanparts.com/uploa...1201651721.jpg http://forums.pelicanparts.com/uploa...1201651730.jpg |
Just Beautiful...........I can hear it.
You must have solid engine mounts judging from the "morse" throttle cable bolted right to the frame. |
Thanks, I stopped using solids mounts as per Richard Parr at PMO (Carbs)
stock on the trans mount and wevos on the engine mount |
Mark, that looks absolutely beautiful, nice job.
Drove around coto de caza at 8000 RPM! Ha ha ha! Look out! :) |
Looks good Mark.
Are you going to test at BWRP Feb 9&10? I've still got a lot to do to get the car back together... |
Probably use the friday before our CA Speedway event to dial her in. |
Beautiful engine. Nice detailing.
Thanks for sharing. |
Yehaw, very neat !
Congratulations! Beautiful work. Quick question though. Any concern that a slight fuel drip at the regulator could land on your fuse block on the crossmember? Perhaps I'm overly paranoid, but I try to keep electrical and fuel lines as far apart as possible in the engine compartment.
Very nice work!! Did you use a fuel pump inertia switch, just in case?
http://i23.ebayimg.com/02/i/000/d2/79/ad36_1.JPG |
I must say thanks to JB Racing for their twin plug Dist. I ran the same system on my 2.5L last season and all season, on issues, same w Richard Parr's PMO's, again both engines no issues. I bolted on the PMO's to the 2.0L and Adj. the idle and that was it!
JB Racing's clutch package had no issues all last season too. Very good quality. |
Now, bring it over to the east coast and let her rip on some HSR (east) events.
from here I can't see anything illegal with it; but if you say so ;)
I run PMO 46's. You can on the 911 class but not on the FIA 911 class. If you run a crankfire ignition you get a weight penalty.
Not sure how light you are but the limits are not unreasonable - 2050 with driver at end of race and (I'm glad to say) that they actually check the cars at the end of the race. All Vintage Classes of Porsches a. No Camber Plates b. Stock pickup points c. No Crank fired ignition d. All cars must have MSD Rev limiter with 8200 RPM max Chip e. No Coil Over Shocks f. 1973 911 “S” Brakes Maximum for Klub Sport Challenge 2.0 LITER 911/914/6 PORSCHE ENGINE 1. 2.0 Liter 81mm Bore Maximum X 66 mm Stroke 2. Weber or PMO Carburetors up to 46 mm or Bosch Mechanical Injection as supplied on 1969 911S 3. Distributor fired MSD 6AL with 8,200 RPM rev-limit chip or MSD Soft Touch Rev control with 8,200 RPM rev-limit chip, distributor fired ignition (Must be mounted out of reach of the driver). 4. Twin Plug – OK 5. Heads are to be original 2.0 Liter components. (45mm Intake Valve, 39 mm Exhaust Valve maximum diameter.) ** Aftermarket components must be pre-approved. TRANSMISSION 1. Factory - Supplied Gearbox as per year of manufacture. – 5 Speed 2. 901/911 Transmission – OK 3. Gear Ratios – OPEN 4. No progressive shifters, no paddle shifters; shifter may be altered to accommodate driver seat position but must be a standard 5 speed pattern manual shifter. BODY C 911 Body to remain stock up to 1969 configuration C 914 stock or “factory configured” 914-6 GT body work is ok C Seat position to remain stock. 1. Up to 1969 911 Front Bumper Required 2. Tub to remain stock and complete - bolt-on Panels/Material – FREE 3. 911 – will be 2,050 lbs with driver. (All cars will be weighted with driver as raced at the end of each race.) 4. 914 /6 – will be 2,125 lbs with driver. (All cars will be weighted with driver as raced at the end of each race.) 5. Tube Frame Chassis – ILLEGAL 6. Dzus Fastened Panels (Exterior Panels) – ILLEGAL 7. 914 Windshield or Roadster – OK WHEELS 8" x 15" maximum width and diameter Rear 7" x 15" maximum width and diameter Front TIRES 1. 225 X 50 X 15 Maximum Size Radial Rear 2. 205 X 50 X 15 Maximum Size Radial Front 3. 50 Series Lowest Profile 4. Street DOT Radial (HSR Approved Tires Only) DOT radials as follows: Toyo Proxes RA1 Khumo Escta V700 Yokohama AO32 Hoosier- New prototype in testing. We will advise through the HSR website as to the results and eligibility of this new tire. SUSPENSION 1. The Suspension must be exactly as fitted by the original manufacturer as to type and location. 2. Coil over springs and remote reservoir shocks, including newer internalized reservoirs, NOT allowed 3. Anti sway bars- free so long as they fit on or into factory mounts and pickups. 4. Bushing material free including spherical bushings on front upper strut mounts and rear trailing arms. 5. Torsion bars- free to the extent they fit into stock torsion tubes and A-arms. 6. No camber boxes. 7. No billet front shock mounts. BRAKES 1. Brakes up to 1973 – FACTORY STEEL OR ALLOY “S” SUPPLIED CALIPERS AND ROTORS. 2. 1978 911SC Front Caliper (Cast Iron A Calipers) may be substituted in front. |
| All times are GMT -8. The time now is 04:57 AM. |
