-   -   Help needed identifying Heads, Cam (http://forums.pelicanparts.com/911-engine-rebuilding-forum/390264-help-needed-identifying-heads-cam.html)
hbrand 01-31-2008 06:38 AM
On a complete engine, I removed cooling shroud . I have 6 cylinder heads, all are dated 10/68, number next to date is K1819D, the are MFI, intake port is 32mm
The cam has stamping NE.
Thanks, Harold
304065 01-31-2008 06:59 AM
What is the number on the other side of the heads? Should start with 901 in a circle.
tom1394racing 01-31-2008 07:54 AM
The heads are 69E.
See this reference table.
http://www.carquip.com/parts/911/engines/cyltbl/index.asp
hbrand 01-31-2008 08:18 AM
