911s 1977 2.7
The # 4 cylinder broke, and two ther are damaged. And I'm thinking on replacing all cylinders and pistons with 90mm (2.7L) piston and cast steel cylinder set for Porsche 911 (http://qscusa.com/Porsche.htm). The original pistons and cylinders are Alusil.
Any advise??? |
Air Medal or two
$$$$$$$$ is always the issue. Go Mahle if you can
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
