Kevin Taylor's Avatar
Oil Tank Install On 1978 911 SC
I recently installed my oil tank in my 78SC. After completing
the job I found a couple of rubber spacers with metal center's in
another coffee can I had been keeping all the nuts and bolts.
Are they supposed to go on the oil tank first......outside the engine compartment?
Between the body and the engine compartment?
I have searched and can not find a good enough diagram showing the installation of the oil tank.
Thanks In Advance for your help.
K.T.
1973 911 E 2.4 MFI
1983 911 SC
1978 911 SC
1965 Devin "D" / 1967 912 Power Plant
1998 GMC Serra 4X4 Z71
John Deere LT166
Money Can Buy Happiness........Buy A Porsche......a
Old 02-07-2008, 08:54 AM
Kevin,
FWIW, this is the factory mounting hdwe that was installed on my '79. No rubber spacers with metal centers, just these plastic or wax appearing isolators and shrouded metal washers. If I remember correctly, they sandwich both sides of the engine compartment wall and effectively isolate the tank mounting tabs/studs from the body. The only rubber isolators I remember seeing were used to isolate the fuel filter/accumulator assy and the electronic panel on the opposite side. Hope this helps.
Mike
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold
Old 02-07-2008, 09:17 PM
Thanks for your reply and picture Mike. Yes, those are the ones
I used to install it with.
Looking around in my basement this morning I found another
oil tank with the identical hardware so I'm confident I have it
installed properly. Sure glad I will not have to pull it back out.
As for the other spacers I guess I will find out where they go
as I continue my build.
Thanks again ........ the picture helped me a lot, It's been years
since I have had one of these out of a 911. Have Good Day.
K.T.
1973 911 E 2.4 MFI
1983 911 SC
1978 911 SC
John Deere LT166
Old 02-08-2008, 05:38 AM
