964 Cams question
Hello guys,
Just a quickie : Will the cams from 1992 3.6 engine fit a 1988 3,2 w/o modifications ? Thanks! SmileWavy |
You can use a factory 964 cam in the 3.2 but you have to grind off the power steering pump gear that's on the cam end. For not much more than the price of a used set of 964 cams, you can get your stock 3.2 cams reground to 964 profile.
Good topic here http://forums.pelicanparts.com/porsche-911-technical-forum/181122-964-cams-3-2-carrera.html |
| All times are GMT -8. The time now is 10:29 PM. |
