Opinios please!
Hello guys,
I plan to install 40 Webers in my 3.2 euro engine (as it missing all the electronic stuff from the injection). I want to add some more HP but w/o to take it apart. So, 964 cams is a good idea or something more agressive ??? Is there any engine management system that can be used with the stock 3.2 intake but w/o the motronic stuff ??? Thank you for your great help SmileWavySmileWavySmileWavy |
I think the 993SS cam is a good choice for the 3.2. Do a search here to confirm.
You can use just about any engine management system you want. You might have to make custom fuel rails if you don't have any. Take your pick from highly user based (read: build and assemble youself) Megasquirt through Motec, there are systems for all budgets. I suggest searching EFI and reading lots of posts here on the board. Then take that information as a base to learn more. |
| All times are GMT -8. The time now is 04:52 PM. |
