Question 2.8SS from 911SC case
Help,
I need to know whether it is possible to build a 2.8ss from a 911SC case.
I understand that i will need a custom/billet crankcase but are there any other reasons why this can't be done
Accepted that every one will say use a 3.0 Carrera case or 3.0 Turbo case as they use the same crank as a 2.7 motor and therefore i could then use a 2.0 or 2.2 crank.
Where would I buy a billet crank or can i have my SC crank custom offset ground and re hardened.
thanks in advance
Michael
Old 02-28-2008, 05:52 PM
I've made severely underbored cylinders to make 2.5 engines out of 3.0/3.2 and 3.0 out of 3.6 engines, so anything is possible.
As far as the crank work, billet or offset ground, http://www.racespecs.com/ can probably do it for you (they are in New Zealand). They are doing some billet four cylinder cranks for us and also are doing our type 4 billet heads for us as well.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 02-28-2008, 06:46 PM
Skunk works
JV911SYDNEY's Avatar
if bigger is better, why reduce capacity?
is it to comply with racing regs and have rev-happy motor?
please enlighten me
964 RS-4
Old 02-28-2008, 07:46 PM
bigger is not always better.
A mate and I are looking at building a 2.8RSR replica however the issues of pulled head studs etc with a mag case is a concern so the best bet is to use a alloy case and since a 3.0 carrera or 3.0 turbo are approaching stupid money we are looking at the SC case.
Michael
Old 03-01-2008, 11:54 PM
Right on the money, to comply with displacement limitations while allowing the use of later, more robust engines.
Charles Navarro
Old 03-02-2008, 06:00 AM
boba's Avatar
You could also source a 956 crank. It will work in the SC case. There are a few around. I was offered one about a year ago with Ti rods, it may still be available. Not cheap but neither is the other path. PM if interested.
Regards,
Bob
Old 03-02-2008, 07:42 AM
Skunk works
thanks mate!
964 RS-4
Old 03-02-2008, 12:50 PM
Bob,
thanks for the thought on the 956 crank but i was thinking that if i get a custom/billet crank made then i will get the benefit of 20+ years advance in technology whilst still ending up with the displacement.
Charles as i get closer I will send you an email re pricing on nickies with a reduced bore.
So does anyone have any ideas where i can get a custom crank made?
Michael
Old 03-02-2008, 12:53 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Just to clarify what we are talking about here:
making a 66mm-stroke crank that is also a 9-bolt
the 2.0/2.2L crank, with its rev-happy 66mm stroke, was only made in a 6-bolt version, save for the 956. To run this in a case that has 3.0 heads and pistons/cylinders, you need a 3.0 Carrera or 930 case, which are pretty hard to find.
The idea is to use a standard, readily available 3.0 SC case or 3.2 Case with a 9-bolt, 66mm-stroke crankshaft. The standard bore of the 3.0/3.2 is 95mm, and that gives you exactly 2,807cc of displacement with a 66mm stroke. You do not need to underbore it, I don't know why you would unless you have to get under 2.8L. This compares extremely favorably with the factory 2.8RSR that was 92 borex70.4 stroke for a displacement of 2,808cc.
Michael-sent you a pm
Scott Kinder
kindersport @ gmail.com
Old 03-02-2008, 02:23 PM
Well, the idea would be to be able to use the 3.0 crank and not need a custom crank, with the 92 bore and 70.4 stroke - that is exactly what I have done before, or at least one example of an underbore cylinder. Doesn't cost any more to make it that way.
Charles Navarro
Old 03-02-2008, 03:24 PM
gestalt1's Avatar
can a collar be made to hold the main seal for a 6 bolt (66mm) crank in an sc/carrera case? basically reducing the diameter of the bearing area for the early crank. are there other differences?
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 03-02-2008, 03:30 PM
I understand that i can use the standard crank as per charle's comment but I would be seeking to have a stroke of 66mm to get a really high revving motor
If I undersatnd it correctly a 66mm stroke and a bore of 95 will give me 2.8ss
Or the other way i can go is a stroke of 70.4 and a bore of 92mm
I think the 2.8ss motor will be a better performance compared to the longer stroker smaller bore.
Michael
Old 03-02-2008, 05:59 PM
There is nothing saying you can't have a longer stroke while making an engine a revver, especially considering that a 70.4mm stroke isn't that much (Porsche 356/912 is 74mm and those engines rev freely, even with a 90mm bore and some a bit larger yet). Other considerations could be made to build either configuration into a revver - plan with cam timing (and cam itself), light flywheel, lighten wrist pins and pistons, etc. All things considered, the longer stroke will yield itself to higher piston velocity and with a smaller bore, should have better flame front. Not saying that one is better than the other, just the 2.8SS is the more common approach.
Charles Navarro
Old 03-02-2008, 06:08 PM
YTNUKLR's Avatar
The 2.8SS is "2.8 Short Stroke". That means it has a shorter stroke~requires 956/custom crankshaft, to run 95x66, or a 3.0 930/Carrera ('75-77, typ #930/02 and 930/52) case.
Sure, you can make a 2.8 out of a 3.0SC, if you do 92x70.4. It's a 2.8, but it definitely isn't a 2.8SS.
Math (formula 6(pi)r^2h):
6(3.1416)(95/20)^2(6.6)= 2806.94 cc ;; 2.8 Short-Stroke, 95 x 66
6(3.1416)(92/20)^2(7.04)= 2807.95 cc ;; 1973 2.8 RSR, 92 x 70.4
I have built several 2.8SS engines. I hope this clarifies things.
Regards,
Scott
Scott Kinder
Old 03-02-2008, 08:03 PM
