-   -   camshaft and valve timing data needed (http://forums.pelicanparts.com/911-engine-rebuilding-forum/393101-camshaft-valve-timing-data-needed.html)
bruboy 02-16-2008 06:30 AM
I'm trying to find some data on valve timing for the SC and 964 style camshafts.
So for an SC cam timed at 1mm what are the actual inlet and exhaust valve opening and closing figures
also the same question for a 964 cam timed at 1mm
I've looked in Freres and I think the data is wrong,
thanks
hcoles 02-16-2008 10:15 AM
Camgrinder (John Dougherty) should be able to help you, he will know the differences and exact numbers.
