3.2 removing blower motor duct ?
In the picture below (courtesy of trown_hammer) is a 3.2 engine with the heater duct replaced with a steel piece.Is this a SC,2.7 or older or I have to fabricate one from scratch ???
http://forums.pelicanparts.com/uploa...1203268410.jpg Thanks!SmileWavySmileWavy |
Shawn's was fabricated but you can get one from an earlier engine that's got only a small snorkel it instead of the big wide tube that the 3.2 typically has.
I bought a used 3.2 piece and cut off the wide tube. Then I cut a piece of sheetmetal to cap the opening. |
Thanks for the info Kevin!
| All times are GMT -8. The time now is 06:40 PM. |
